Old 12-04-2010, 08:08 PM   #18
tucsonjwt
Re: I need help now !!!!!!!!!
D-Day - In your case, I vote for upper steering column rebuild - a task beyond my skill level, so I had a pro do mine - very pricey, even if you know what you are doing. I went all around the steering column (ignition switch, neutral switch, etc.) before I bit the bullet and paid the $$ to fix it right. You can search the net for some info on this repair. I just have never had any luck when I bust open a steering column.
tucsonjwt is offline   Reply With Quote
