Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 12-03-2010, 10:51 PM   #1
69trk
69trk's Avatar
drop member and drag racing
If i lower my truck on the front from a 2.5" to a 3.5" and the rear from a 4" to a 6", will i need a drop member for drag racing? Just want to make sure the aluminum driveshaft doesn't hit. I already have shock relocators on it and the adjustable trac bar...
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline   Reply With Quote
Old 12-03-2010, 11:39 PM   #2
Hart_Rod
Hart_Rod's Avatar
Re: drop member and drag racing
Mine's lowered 6.5 in the rear and I still have good clearance. I'm getting ready to add a drop member though, so I can have the exhaust cutouts and center the rear wheel better in the wheel opening.
Hart_Rod is offline   Reply With Quote
Old 12-03-2010, 11:46 PM   #3
69trk
69trk's Avatar
mine is centered perfect, and i got a knockout set and knocked out some 4" holes in my existing crossmember...
1.58- 60'
11.37- 1/4 @115.81
Old 12-05-2010, 02:44 AM   #4
68 C-10 KID
Mean Green
68 C-10 KID's Avatar
I went with the Drop member and had Him put a offset in the lower loop.
Mainly because of the 5" drive line OD. I didn't have any down ward suspension travel before the drive shaft was resting on the cross member.
This is also a excellent piece do to the adjustment you get out of it.
With that and a pair of coil overs I think a truck should hook good with a little tuning.
427 SBC 683HP & 590ftlbsTRQ @ fly wheel.
60'-1.38 1/4-10.43 MPH-124.6
New ET current 4/2019
AKA MEAN GREEN.
68 C-10 KID is offline   Reply With Quote
Old 12-05-2010, 10:01 AM   #5
69trk
69trk's Avatar
where did you get your dropmember?
1.58- 60'
11.37- 1/4 @115.81
Old 12-05-2010, 11:18 AM   #6
Hart_Rod
Hart_Rod's Avatar
Looks like a Porterbuilt one.
BOOMER!!
Old 12-05-2010, 11:21 AM   #7
69trk
69trk's Avatar
thanks...
Sooner
1.58- 60'
11.37- 1/4 @115.81
Old 12-05-2010, 01:04 PM   #8
68 C-10 KID
Mean Green
Hell yes is a PORTER BUILT!
Its Rocks. Way better than the CCP one I had previous. Nate and his shop builds real nice stuff. It goes in real easy. The old one might be a hassle getting it out. couple of the upper rivets are a pain.
AKA MEAN GREEN.
Old 12-05-2010, 01:42 PM   #9
Super73
Super73's Avatar
I know Porter build some good stuff, but I have a couple questions...
Is there really any added benifit over a modified stock x-member?
For instance, I think I made my adjustable lower control arm mounts prior to the cross member being available. So is there an advantage to porters over what I did?
I know the exhaust can pass through, but I can easily cut mine a little bigger with my plasma and clean it up with a flapper wheel, so is there an advantage to his unit there?
The next I'd point out is weight. His piece is definately built well and looks heavier than the factory piece. Is that the case? I guess in racing that would be a down fall..
Now I'm not trying to knock his piece at all.. So please don't take it that way. I'm just wondering if it would have any added benifits for someone in my position who has already modified there OE piece.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 12-05-2010, 05:35 PM   #10
69trk
69trk's Avatar
check this one out. I emailed nolimit to see if they would just sell the crossmember. I wouldn't have to undo the exhaust, just the driveshaft...
1.58- 60'
11.37- 1/4 @115.81
Old 12-05-2010, 07:40 PM   #11
68 C-10 KID
Mean Green
Nope. Super your mods are great. Only advantage is the drive line tunnel allowed me run a bigger OD DL.
I think his piece did way weigh less.
AKA MEAN GREEN.
Old 12-05-2010, 07:43 PM   #12
68 C-10 KID
Mean Green
Porter built does a similar set up that I'm saving up for!
You should check it out.
AKA MEAN GREEN.
Old 12-05-2010, 07:50 PM   #13
Hart_Rod
Hart_Rod's Avatar
I think his setup will allow you to adjust your pinion angle also...
68Kid - Does the rear sway bar help much?
Old 12-05-2010, 07:59 PM   #14
68 C-10 KID
Mean Green
Yes his does, for every hole its a deg + or - Super found that out when he modded his.
It works great for the road and the track. It seams to make the truck plant the foot print more square.
Only thing it makes the truck feel like the tires are a little more bound around tight turns with the spool.
I would like to build a set up like some the other guys are doing with the anti roll bar's.
AKA MEAN GREEN.
Old 12-09-2010, 02:52 AM   #15
Super73
Super73's Avatar
68 C-10 Kid is right.. It adjusts pinion angle only with the arc change of the arm. So as it adjusts instant center it inherantly adjusts pinion at the same time, but you can not adjust them seperately.
