Front end 73-87 swap for a 69 chevy, is it worth it???
I have a 69 chevy c20 that im looking to swap out to a 5 lug and im wondering is it really worth it to look for a newer front end instead of one that will just bolt up, i have a couple of front ends from this erra of trucks that i could use but wanted to get info before i do anything.
1969 Chevy c20(Miss Hackjob) |
Re: Front end 73-87 swap for a 69 chevy, is it worth it???
YES, cheaper parts........the only reason to change the crossmember is so you can drop the oil pan easier otherwise use the 69 crossmember bolt the later model 5 lug stuff complete.
Steve |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
The 73-87 complete crossmember will bolt up. You will have to elongate two holes on each side but thats it. Well worth the time!
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
Can i ask how much would one of these cost? If you guys dont want to talk about it i understand lol, im just trying to figure out how much itll cost.
Grandpa in the rustmobile...
Id say you could score on for round 100$
I sold a whole rolling frame to a friend for 75$ lol
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
Thanks a lot! What should i all grab from the donor truck when i do it?
