Old 12-04-2010, 11:13 AM   #1
classicfins
472 Caddy in a 67-72?
Just curious. Has anyone here ever shoehorned a 472 Caddy engine into a 67-72 Chevy? I know there is room, just mainly wondering if anyone has done it and if there were any major obstacles that caused problems.
classicfins is offline   Reply With Quote
Old 12-04-2010, 11:38 AM   #2
CG
BlahBlahBlah
Re: 472 Caddy in a 67-72?
I dont know if a 472 is the same as a 500 but there have been lots of threads on the subject. Maybe do a search on Caddy or Cadillac?
Old 12-04-2010, 11:39 AM   #3
Simonstrucker
Big Block Short Bed Stepside
look up longhornman he did it twice.
Big Block Club
Short Bed Stepside Club
Disk Brake Club
Simonstrucker is offline   Reply With Quote
Old 12-04-2010, 11:51 AM   #4
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
500 is just a bigger 472.
Member Nr. 2770
Old 12-05-2010, 11:59 AM   #5
69 longhorn
There is a pick of a 425 cad that ran a couple seasons in my longhorn....just dig through my webshot pics.
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 12-05-2010, 01:18 PM   #6
cadillacart
1972 C/20
cadillacart's Avatar
472 is a 500, I think the only difference is the crank. If someone says 500 block, they can mean a 472 or a 500.
http://67-72chevytrucks.com/vboard/s...d.php?t=313233
My Gallery
1972 C/20 402
Gramp's Truck
cadillacart is offline   Reply With Quote
Old 12-05-2010, 02:50 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
yes, the crank is the main thing between a 500 and a 472.
A quick rundown of how I did it...
Need a BOP trans to bolt up, possible drive shaft mods depending on tranny chosen
Fuel line run onto other side of engine.
Dimple firewall on drivers side
flatten the flair on passenger side frame rail up towards the front.
use 73 - 87 truck engine stands, drill large hole in center, and lop off front lower corner (upon mock up you'll see where it's needed and why)
Caddy rear wheel drive manifolds, rear sump pan, I used eldorodo motor mounts, a 425 oil pump is smaller and clears the front crossmember with no trimming, a 69 472 fuel pump is 3/8 in and out with no return line... I think that's about it, plus some moving of wires around under the hood to relocate the alt onto the passenger side.
You'll want a 3.07 gear if it is a street driven truck.
4 row rad is a must
get strong U joints
bald rear tires are a common problem too.
MPG generally goes up considerably once you stop playing with the torque and just driving it.
Old 12-05-2010, 03:02 PM   #8
classicfins
Great info guys. Thanks a million!
Old 12-05-2010, 10:46 PM   #9
Longhorn Man
there's little details that I have long since forgotten, but that is in all reality the main things to the swap.
Old 12-06-2010, 12:37 AM   #10
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Over 80K posts now LHM?......unbelievable!
prostreetC-10 is offline   Reply With Quote
Old 12-06-2010, 01:00 AM   #11
Longhorn Man
I've been here just shy of a decade too though.
Old 12-06-2010, 01:40 AM   #12
prostreetC-10
My Carbon Footprint
That would be 3650 days into 80,330 post which comes out to be 22 posts a day.....EVERYDAY. Dare I say "post whore"? lmao
I remember when it was 75K and I thought that was a ton. This is a good place to pitch a tent and camp out though huh? Thanks for all your great information! This is totally in fun....
Old 12-06-2010, 03:57 AM   #13
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
80K is insane! I was stoked the other day when I hit 1000 .
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 12-06-2010, 10:21 PM   #14
Longhorn Man
i spent a few years here when I had nothing else better to do.
Old 12-06-2010, 10:48 PM   #15
prostreetC-10
My Carbon Footprint
I'll be the first to say that my wife has told me more than once to get off the damn forum and get something done. I just tell her I'm providing good, technical information.
Old 12-06-2010, 11:05 PM   #16
69 longhorn
Dont lie to her....you know you were playin crazyAl
Old 12-06-2010, 11:10 PM   #17
81ShrtBox
MadMan
81ShrtBox's Avatar
I have a buddy with a 472 he's about to throw on Ebay. His grandfather ran a funeral home and this engine was in one of the hurses. Car was a local driver, not many miles..
81ShrtBox is offline   Reply With Quote
Old 12-07-2010, 12:01 AM   #18
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Been there done that check my build for all the info and not to step on LongHorns toes but I didn't "tune" the fire wall...it's 100% bolt in if you use the right parts and I did it by myself in 3 days including cleaning and painting everythin which took a day...If you have any questions I'll do my best to help out
Jeff
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 12-07-2010, 12:16 AM   #19
Longhorn Man
I didn't have to, but I wanted an inch or more between the drivers side valve cover and the firewall.
There's a million ways to do it.
Old 12-07-2010, 12:54 AM   #20
69 longhorn
I CUT the firewall, on my Cad swap....I wanted the weight as far to the rear as possible! He!! it was only the gas peddle that had to move back 1 inch I will tell you square, I didnt do a "3 day build", but it was "dead nuts" when it was done Andy said it right....there are a million ways to do it You can do it fast & dirty.....or play the fab man. If you can play fab man in 2 or3 days, my hat is off to you(you are a better fab man than this old man crazyAl
