Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 12-07-2010, 03:56 PM   #6
Marv D
Registered Truck Offender
Marv D's Avatar
Re: Can you guys check this crank out for me
You still need to add / remove weight when you balance a externally balanced motor. The external weights are a 'fixed' item. You can't add to the scalloped harmonic damper, so balancing is still done at the crank. If you put a light weight small skirt piston , long rods in a externally balanced motor, the 'stock' crank balancing is off.
Now is this internal or external balanced motor..... them apper to be BIG slugs of mallory!!! But only one way to know. Weigh the parts up and have your machinist spin it up. Then you'll know for sure.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
