Old 12-09-2010, 10:22 AM   #1
Ellington
My 1946 International K-1
I haven't posted much on here but have looked around a lot and thought I would post some pictures of my somewhat rare project. It's a 1946 (titled as a 47) International k-1 pickup with a factory flat bed that my father in law gave me. His dad bought it in Southern California from the military at some point. Not sure when though. It is going to be a slow build like any other project time and money is a factor.
It has a flat head straight six with a 3 on the tree shift. I don't think I will use this setup because to get the motor running it is going to be way expensive. It hasn't run since 1980. My plan is to put a mustang2 frontend on it. Put a sbc and 700r4 trans combo with a narrowed ford 9 inch. As for the flatbed part i am unsure about it. Don't know if I want to find a bed for it or stick with a flatbed. I have some time to think on that one. Here are some pictures.
Ellington is offline   Reply With Quote
Old 12-09-2010, 10:24 AM   #2
Ellington
Re: My 1946 International K-1
more
Old 12-09-2010, 10:25 AM   #3
Ellington
and more
Old 12-09-2010, 11:17 AM   #4
geezer#99
geezer#99's Avatar
Nice project. Those old International's had a nice look to them. There's a guy up north of me who has one. His is painted blue and body is mint. Bought for 3000 from a farm in Saskatchewan. Nobody wanted it. He did. Stock motor for now but has a small block auto and s10 rear going in. His stock motor runs good but the 5.13 gear in the rearend limits his speed. Motor parts are expensive. Zenith carbs are around 500 bucks. Cheaper to go smallblock.
If you want some pics of his let me know. Just some pics for inspiration.
geezer#99 is online now   Reply With Quote
Old 12-09-2010, 11:32 AM   #5
fattyarbuckle
nice project... I think I'd like to have one because they are different.
Here is a friend of mines project.
OH, that glass is rare as hens teeth! Better noot loose it...
fattyarbuckle is offline   Reply With Quote
Old 12-09-2010, 11:33 AM   #6
63 & 64 Bowties
and a few others
Nice truck, but I love the ole corn binders.
Here's a AD truck flatbed that I found on another forum. I've never been a big fan of the halfton flatbeds until I saw this one. In his build tread he mentions how the flatbeds only look good with big wheels on them, and I agree.
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 12-09-2010, 12:14 PM   #7
Ellington
Thanks, there is actually a place called classic flat glass that has all the templates for all old vehicles with flat glass. Not sure how much that is going to cost but I am glad it is available.
Old 12-11-2010, 12:24 AM   #8
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
Make a good template from cardboard and take it to your local glass cutter. I've done it that way for years and never had a problem getting a correctly fitting piece of safety glass. And best of all, it is cheap.
I LOVE your IH!
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 12-12-2010, 01:07 AM   #9
swamp rat
swamp rat's Avatar
I love the corn binder! subscribed!!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 12-22-2010, 12:35 PM   #10
Ellington
well i have the motor out now. That is one heavy sucker. I bent the cherry pick a tad but will get that fixed. I learned that my father in law drained all the coolant out of the motor when he parked it which probably wasn't the best idea if i was going to use it. I am sure its rusted up bad on the inside. The week after christmas I am going to do some more stripping. I am going to measure for my MII front end and get it ordered. Then I will have to sit and wait for more funding to buy my donor vehicle for some parts. I have also decided to go with a triangulated 4 link setup in the rear to get rid of the leaf springs all together.
Old 01-03-2011, 08:42 AM   #11
sixty8c10
MY EX DRIVES A BROOM
sixty8c10's Avatar
I have a similar build in the works. I plan to the s10 fame swap conversion for mine. Mine is a 47 IH KB-2, flatbed. It has a 125in wheelbase. Im using the s10 ext cab chassis for my foundation it is a 122in wheelbase. The s10 I have has a running fuel injected 4.3 v6 and a 5 speed, which I plan on leaving in the binder for awhile. With gas prices the way they are, I couldn't see myself putting a v8 in it. The s10 gets 22mpg, but the body is rotten. I figure with the body swap I should get pretty close to same. The Only change to the drivetrain I plan to make is to go from 24in tall tires on 14in rims with 3:08 rear gear ratio to a 28-30in tall tire and 3:73 rear gear. Anyway, thats enough rambling from me, i won't be starting mine until I return from Iraq.
They say nobody's perfect.
I'm a nobody, so I must be perfect.
Building Nemo -1968 C10 Long Bed
FRED -1947 KB-2 International
sixty8c10 is offline   Reply With Quote
Old 01-12-2011, 09:48 AM   #12
Ellington
Well I ordered my front suspension for the truck yesterday. I hope to start on it in february sometime between work and fishing. We will see how that all goes. then I will get some money saved up for the rear suspension.
Old 01-12-2011, 11:59 AM   #13
Ellington
Also, anyone have some tire size recomendations for me? i am thinking 245/60r15
Old 01-12-2011, 01:22 PM   #14
NONHOG
NONHOG's Avatar
For all 4 ? I'm seeing Big and littles in my minds eye. Not sure what fits.
"I feel the need for speed!"... as soon as I am done with my nap.
NONHOG is offline   Reply With Quote
Old 01-12-2011, 01:43 PM   #15
Ellington
For the front. I want to do a wider tire in the back.
Old 02-28-2011, 01:42 PM   #16
Ellington
I have a little update. I started putting in my front suspension. It was all going really smooth until I mocked in the a arms and spindles. things didn't line up too good. It turns out that they sent me the wrong crossmember and lower a arms. Up to that point it is a really basic install. Lots of measuring for sure to make it all work and place right. here are some pictures.
Old 02-28-2011, 02:46 PM   #17
Kabwe
Certified Car Nut
Kabwe's Avatar
This is a really cool project. Keep the pics coming.
Kabwe is offline   Reply With Quote
Old 03-31-2011, 01:39 PM   #18
Ellington
Well i got the right parts in and welded in. I will get it all put together tomorrow and then get my motor mounts installed. Also had to remove the rear engine cross member. What a pain that was. 5 rivets on each side and the air chisle wouldn't even move them. Had to cut them off and then chisle them. I think our ears rang for a few days after that. Hope to get it drug home so I can work on it at my house tomorrow as well.
Old 03-31-2011, 03:01 PM   #19
63 & 64 Bowties
and a few others
Nice work. What kind of ride height are you shooting for?
Old 03-31-2011, 05:01 PM   #20
Ellington
Well I want it low but not too low. I put 2 inch drop spindles on but if I don't like the ride then I will go back to a standard spindle.
Old 04-05-2011, 01:45 PM   #21
Ellington
Update after the weekend. I got everything welded in. Now i need to start saving for rearend suspension. I also need to get a steering colum fitted.
Old 07-06-2011, 12:00 AM   #22
sixty8c10
sixty8c10's Avatar
Any updates on this project? My 47 KB-2 is with in weeks of being on the road again for the first time since 1957..... I will put together a build thread.....I just need more than 5 minutes to sit in front of this computer to put it up...lol
Old 07-06-2011, 10:34 AM   #23
Ellington
I haven't gotten much done. I am waiting on my transmission so I can weld in the floor pan I am building. I don't know if there is a hump or not yet. Then the next objective will be to buy a steering column and get it mounted. I will be looking for your build!
Old 07-10-2011, 12:18 PM   #24
63 & 64 Bowties
and a few others
What kind of steering column are you gonna use? I bought one from Speedway for my 53. They come in several different lengths. There's a pic in my build thread (link in my sig below)
Old 07-12-2011, 08:42 AM   #25
Ellington
i am thinking of buying one from I did it columns. Theres seem like a pretty cool setup Hopefully here in a few weeks I can get it on order.
