Primer color
if you're gonna leave your truck primered for a while... what color do you choose?
Who Me?
Re: Primer color
If it were me, I would use a black primer.
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
Re: Primer color
I saw one yesterday that looked like dark dark bronze or brown.... almost black
looked good |
Re: Primer color
Dark grey, probly what I'll be doing for the winter till I can get it done correctly
2001 silverado stolen by family 1983 short n wide custom deluxe SOLD 1985 silverado longbed 305 engine 700r4 OH NO! NOT ANOTHER LEARNING EXPERIENCE!!! "Just because you can do it, doesn't mean that you should" |
#5 | |
Senior Enthusiast
Re: Primer color
Just note most primers are porous and will allow rust to form if left to weather. The best primer as a base for just about any paint is epoxy, which seals the metal and also makes a great base for body filler. |
Re: Primer color
what about satin black?
or is that too hard to sand later? |
Re: Primer color
oh and I'm thinking orange, red, or teal for the final color
Re: Primer color
If I was going with one of those colors I would use grey primer.
1982 K10 SWB 1987 V20 - Sold - Doh! |
1962 C-10
Re: Primer color
My buddy's Dad has an old Ford truck. They were able to 'dye' the primer to an almost torquoise color, which was original for that truck. Looks good! I believe they were able to dye it at the paint shop.
Joseph Chavez ![]() "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
Re: Primer color
definitely use Epoxy to seal up metal from moisture and color choice would be gray considering your final color choices.
66 suburban 51 Merc 2 door coupe 38 Chevy Business Coupe (gf's) 76 Airstream Sovereign |
Re: Primer color
You can buy a primer ( many companys make it so pick your flavor and go from there) that you can mix both ways one is a primer only ( easier to sand) the other way it is a true sealer ( will take more elbow grease when you block it) Iused it on my truck for the insides of areas that I will not be painting and you will never see anyways.
Standard primer will rust ... only making more work later. |
Re: Primer color
Normally I would say that dark brown Primer if I was going to drive it but after trying to block sand it I would not use it again....it clogs sand paper pretty bad and just seems to not work as well as Grey...so I would use Grey
Measure with a yard stick Mark with Chalk Cut with a torch ![]() Built it yourself, don't count on others to to do it for you or with you. It will never get done |
Re: Primer color
If you are leaving it primer and it will see any weather, use a 2K urethane primer. It seals well and is tintable to your color. If you are on a tigh budget (and who isn't these days) don't be afraid of the store brand. We use alot of Parts Master primers now in our hobby shop. Also, please note that all laquer based primers will allow moisture to pass and will rust under the primer. Alot of people think that the red primer doesn't allow this to happen, but it does. The rust just happens to match the color of the primer.
Slowly but surely getting it done. |
