How do you prep and paint a 10 bolt, leaf springs and frame.?what is the best type of paint to use?
1986 GMC Sierra Classic 4X4
Re: What is the best way to clean and paint a diff and frame?
use a wire wheel and a wire brush then spray it with tractor paint or por 15
![]() Join Date: Dec 2008
any pics of the parts ? rustoleum if you're on a budget. oven cleaner gets a lot of grease and grime off, cheap too. just don't get it on any rubber lines. not a good pic was done with rustoleum and Dupli-Color Metalcast good luck.
sanding disc on a grinder, lots of prep and cleaning and then prime the crap out of it and bed line over that, tough and looks good i think
take it to a car wash and use simple green or something like that and spay it down the best part of this is you dont have to clean up the mess just drive off
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG |
God is good!
Wire wheel and Rustoleum in the quart size so you can use it with a brush. Did this on a 14 bolt and it looked great. Durable budget minded finish.
Mando "It takes a smart man to know when he's stupid." -- Barney Rubble My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367 |
Here is what i did it worked really really well! I used a chemical stripper ( trick i just learned is t put a bag over it to trap the chemical in keeping from evaporating)
then wiped the stripper off then right away just a wire wheel on my 4.5 grinder here are pictures ![]() ![]() Progress ![]() Primed with 2k epoxy primer ![]() Single stage black ![]() ![]() ![]() stripper appox $20 primer $40 paint $60 Total Cost $120 hope that help man! it was well worth it! Last edited by draggin86; 12-10-2010 at 04:02 AM. |
thanks to all you guys! helped alot
Gee, now that's a classy move.
- Greg |
| Bookmarks |
