Old 12-10-2010, 02:38 PM   #1
Jordans68
2003 z71 tranny problem
i just bought 1 2003 z71 for $1400 it was a deal i couldnt pass up the only thing is the truck wont shift into 3rd gear, it shifts into 1st and 2nd fine i was wondering if that would be the 2nd 3rd solenoid or if the tranny was just junk
Jordans68 is offline   Reply With Quote
Old 12-10-2010, 02:49 PM   #2
Danomt
Danomt's Avatar
Re: 2003 z71 tranny problem
Most likely it is your 3-4 clutch. Pull your pan and if it has clutch material in the bottom then is the 3-4 clutch. most common. I just bought a 96 sub for 500 buck with the same problem. Son put it on the bench and one hour later he was sticking it back in the suburban. Worked fine. DanO
1972 c10 SB
1968 c10 SB
1970 c10 LB
1971 k10 LB
1970 k10 LB
1972 gmc 2w LB
Some projects, some should be.
Danomt is offline   Reply With Quote
