12-08-2010, 07:28 PM | #1 |
700R4 swap to 4l60E
Does anyone know if the computer from a 1990 Chevy 5.7L will control a 4L60E transmission? I swapped the engine into my 70, and then picked up what I was told was a 700R4, only to find out later that it's actually an electronically controlled 4L60E. Is there a way to get this transmission to work with this engine/pcm?
12-08-2010, 08:38 PM | #2 |
Re: 700R4 swap to 4l60E
a 700r4 is not computer controlled. It only has an electronic lockup converter and maybe an electric speedo output.
the 4L60E requires a computer to control it. You can get a standalone computer to control it. Another option that may be better is to get a wiring harness/computer from ~94 chevy pickup that had a 4L60E. I'm not sure how much of the engine is the same between a 90 and a 94, but I would imagine they're pretty close to the same. I don't think a 96+ (I think that's when they swapped to the "vortec" engines was) would work though. Good luck. |
12-08-2010, 08:48 PM | #3 |
Yeah, I was thinking that a 94 pcm might work, but not sure. Any ideas on where to get a standalone transmission computer? Or could the 4L60e somehow be changed from electronically controlled to mechanically controlled?
12-11-2010, 05:37 AM | #4 |
You might be able to get a manual valve body conversion. They are definitely available for the 4L80E, but I don't know about the 60.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians. |
12-11-2010, 07:06 AM | #5 |
I don't know what parts will definately swap over, but do you know what they called the 700-R4 after 1991? 4L60!
T.Y.N Custom Works..... Because "Stock" Sucks! 1971 K 10 GMC Long Bed 1977 Formula T/A Frame off Resto-Mod 1995 FXDL Harley Low Rider 1985 C10 ShortWide 91 Burb front. |
12-11-2010, 08:18 AM | #6 |
Active Member
look at an aftermarket controller from Bauman
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles 18.5" x 31" Hoosier Pro Street Radials ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree |
