Old 12-12-2010, 12:54 PM   #1
Strider76
brake issue - need some advice
Well I'm not the most experienced brake guy out there. Mostly because in all my years I have had almost no brake issues - until now.
What is happening is that my right rear is locking up. I have to really gently come to a stop or it locks. It seems to release fine. It locks both when braking normally and if I use the parking brake. But when I use the parking brake it doesn't seem to go into lock as quickly.
Anyhow, before I get out there in the cold and start pulling axles and drums, I thought I'd see if I could tap the collective wisdom and experience of the forum to see if you could point me in a direction more quickly.
Thanks in advance for any advice.
Strider
Strider76 is offline   Reply With Quote
Old 12-12-2010, 01:49 PM   #2
geezer#99
geezer#99's Avatar
Re: brake issue - need some advice
Wheel cylinder leak or axle seal leak!!! Shoes get grabby when they get wet. Drum pulling time.
Old 12-12-2010, 01:53 PM   #3
OlMech
yep, what geezer said. check the adjustment as well and make sure they are adjusted right, e brake cable not stuck etc.
OlMech is offline   Reply With Quote
Old 12-12-2010, 02:00 PM   #4
HOGDADDY
HOGDADDY's Avatar
I agree my rear axle seal leaked and caused this problem also. This can be very dangerous driving with rear brakes locking up.
HOGDADDY is offline   Reply With Quote
