Old 12-13-2010, 07:11 PM   #1
daverod
SSN 706
daverod's Avatar
69 292 same as 66 292?
Is the engine in my 66 the same 292 engine as one in a 69.
daverod is offline   Reply With Quote
Old 12-13-2010, 08:23 PM   #2
padresag
Re: 69 292 same as 66 292?
no it won't be the same eng, but quite similiar. are you going more modern?
ron
padresag is offline   Reply With Quote
Old 12-13-2010, 08:40 PM   #3
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: 69 292 same as 66 292?
http://www.chevyc60.com/the_engine_page.htm
http://www.stoveboltengineco.com/
http://www.hotsixes.com/index.php?op...&id=2&Itemid=3
The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums
Engine & Drivetrain
http://67-72chevytrucks.com/vboard/f...splay.php?f=24
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
Last edited by 1Bad62Pro/Street; 12-13-2010 at 08:44 PM. Reason: http://www.chevyc60.com/the_engine_page.htm
1Bad62Pro/Street is offline   Reply With Quote
Old 12-13-2010, 10:01 PM   #4
daverod
SSN 706
daverod's Avatar
ron
No I was trying to find a power steering bracket. One on ebay the guy had ia 63 truck but the engine was a 69. Can't believe they are so hard to find.
Old 12-13-2010, 10:14 PM   #5
padresag
it should be the same casting. I don't know what year that they changed the length of w/pump on the v8s. I don't know whether or not that change was made on the I6's, that would be the only difference if there was a change. someone will say something on it
ron
Old 12-14-2010, 02:49 AM   #6
murdoc
murdoc's Avatar
my power steering bracket came off a 1970 c-10 292. it bolted directly to my factory installed, original 292 in my 65. you wont have any problem between the years you mentioned.
murdoc is offline   Reply With Quote
Old 12-14-2010, 04:04 PM   #7
Shaky
Six in a row makes it go...
Shaky's Avatar
I believe they changed the size of the bolts that hold the flywheel on in '67 or thereabouts. Other than that and the carburetor I don't think there's a lot of difference.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 12-15-2010, 01:10 AM   #8
pestwagon
rare as hen's teeth!!
pestwagon is offline   Reply With Quote
Old 12-15-2010, 09:52 AM   #9
dracko
dracko's Avatar
pretty sure there is a thread on here about converting the brackets for earlier 6's to the later integral head style. Not as nice looking, but way cheaper.
dracko is offline   Reply With Quote
