Junk Yartist
Re: NV4500 swap is underway
Hmmmm... what hydroboost are you using? can you post some pictures of the h-boost and the ports? This is an area I amy be able to help you out in!
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
#2 | |
Windy Corner of a Dirty Street
We solved the problem Saturday by cutting the metric tube nut off the booster to gear hose then added a standard tube nut and reflared it. Same deal that I had to do when I first installed this exact late model p/s pump on Gen VI 454HO that I installed back in 2003. Just one of the hassles of these type custom dealeos. Thanks for the offer though.
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
Junk Yartist
Good! Hope it wasn't too much of a headache! One question, is your 8.1L set any further back than what was originally in your truck, I kinda wanna see where your shifter ends up being located.
The 8.1L sits in the same spot as the 454 and 350 before it. Even used the same engine mounts. Didn’t even have to do any exhaust work going from the 454 to the 8.1L
Hoping to get the trans stabbed this week so we’ll know soon where the shift tower will end up.
#5 | |
465 before it came out ![]() 465 ![]() NV4500. Looks as though the shift tower sits back about 4 inches. ![]() ![]() ![]() I am not happy with the AA 205 shifter bracket being the floor will have to be hacked up to make room for the lever so I have an email into ORD to have a twin stick made. Not that I really want a twin stick, I just want the lever to land in a nice spot and not wobble all over the place.
Junk Yartist
Are you happy with where the shift knob is? It will be a relief if I don't have to do too much modification to get it in a comfortable and good looking location in my 70.
205 shift lever... I had thought about making my own bracket to locate the shifter where I wanted it... its a little more fab but I am NOT going to even consider a twin stick. It just wouldnt look right. On IH pick-ups they had divorced 205s, the shifter was mounted on a bracket off the frame and it had a tierod that went back to the t-case
#7 | |
