Old 12-13-2010, 05:57 PM   #1
blackbeaSSt
What kinda battery are you running?
in terms of cranking amps and cold cranking amps? and also your engine setup just to compare and contrast!
blackbeaSSt is offline   Reply With Quote
Old 12-13-2010, 06:37 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: What kinda battery are you running?
I went to Pep Boys and got a 775CCA battery off their shelf for mine
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 12-13-2010, 06:41 PM   #3
qu1cks1lver56
qu1cks1lver56's Avatar
XS Power D3400. Not really rated in cranking amps, but it does a burst discharge of 3300 amps, and has 67Ah capacity. Spins my mini starter like its cranking a honda.
edit: Mild 350, 9.6:1 compression.
qu1cks1lver56 is offline   Reply With Quote
Old 12-13-2010, 06:42 PM   #4
goatwrangler
just got a wally world special...690cca for my 350ci
Jason
1989 Crew cab 2wd 8 lug and staying that way
88M 638th ASB Lafayette, IN
goatwrangler is offline   Reply With Quote
Old 12-13-2010, 06:46 PM   #5
Restrorob
The One And Only !!!
Restrorob's Avatar
780/980 Yocam for my BB, Will run the same with my built SB....
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 12-13-2010, 07:08 PM   #6
Hubscrub
Cruzin
Hubscrub's Avatar
dekas, one ac delco
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 12-13-2010, 10:04 PM   #7
tucsonjwt
Autozone Duralast Gold - dual start batteries for my 454. I am on my third pair in 6 years. Autozone changed them out for free twice - I wonder if they will do it a third time in another two years or so. I don't drive the truck very much, so it is hard to keep a charge on them.
tucsonjwt is offline   Reply With Quote
Old 12-13-2010, 10:16 PM   #8
Bow Tie Scottie
Bow Tie Scottie's Avatar
This Deka 60 dual-post battery I installed this past Summer.
Sit back. Relax. Enjoy the ride!
86 Chevy Scottsdale C20, SBC 350, TH400, 4.10 gear ratio
Bow Tie Scottie is offline   Reply With Quote
Old 12-13-2010, 10:16 PM   #9
83burban
Optima Reds in both single and dual battery cars...only battery I run in any older gasser
83burban is offline   Reply With Quote
Old 12-13-2010, 10:23 PM   #10
donut
donut's Avatar
Mild 350, Wally World bat., about 730cca. Fired up the plow down to -25. iirc it's an "Energizer"
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 12-13-2010, 10:23 PM   #11
SBTork
Garage wrench
SBTork's Avatar
ACDelco 786YR 700CCA battery in my suburban. It was bought for my '86 C-10 in winter, early 2006 and have not had a problem yet with it. It has been in three vehicles now.
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 12-13-2010, 10:28 PM   #12
Justins76
OutOfMyMind & I'llNeverKnowWhy
Justins76's Avatar
Walmart 780CCA on 350cid.
-Justin-Out of my mind and I'll never know why
1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed
1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6
1992 Pontiac Firebird T-Top 5.0L TBI 700R4
My cardomain page
I don't like to save, it's more fun to spend!!
Justins76 is offline   Reply With Quote
Old 12-14-2010, 01:07 AM   #13
TheWhiteElephant
God is good!
TheWhiteElephant's Avatar
Going to use an Optima red top on the K20. I've been using them for years. Some on the 'net say the quality is no longer there but I would strongly disagree. I had one in my '65 Impala that I'd start maybe once every few months and it would always start right up after priming the carb. Once I went much longer than that and all I had to do was quick start it with a charger and it kept starting right up after that.
Mando
"It takes a smart man to know when he's stupid." -- Barney Rubble
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367
TheWhiteElephant is offline   Reply With Quote
Old 12-14-2010, 03:28 AM   #14
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Optima red cap battery. I use all four posts!! Two are for the battery. The other two post run fans, stereo and alternator connections.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 12-14-2010, 06:37 AM   #15
S10Fan
Old Heap Driver
12 volt
800cca I think, have to check. A good tough battery will keep starters happy and make them long lasting.
The two most common items that keep you parked after stopping are starters and batteries. If you're going to short cut either one make sure you have a charged up cell phone or new shoes. LOL.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 12-14-2010, 06:00 PM   #16
87 V20 Scottsdale
87 V20 Scottsdale's Avatar
I've got a Deka 1100CA 900CCA dual post on the V20 and two Deka 750 CCA side post batteries on the K30.
Andrew
1987 V20 Scottsdale 383 TBI, SM465, NP208, 14FF, 4.10
1988 C1500 Scottsdale 305, 700R4, 3.08
1986 K30 Custom Deluxe 6.2, SM465, NP205, 14FF, 4.10
87 V20 Scottsdale is offline   Reply With Quote
Old 12-14-2010, 10:24 PM   #17
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Dual Exide Orbital Gell cell's in my 'Burb.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 12-14-2010, 11:45 PM   #18
dbmx66
optima red
dbmx66 is offline   Reply With Quote
Old 12-15-2010, 12:33 AM   #19
bitchin85
bitchin85's Avatar
i say optima red top also.. i dont have it in my chevy (wal-mart special) but i have one in my v10 dodge and it started right up in below zero weather.. and i have no idea how old it is. the PO put it in and theres no date on it...
"I'll keep my guns, money, and freedom. You can keep the "change"
bitchin85 is offline   Reply With Quote
Old 12-15-2010, 01:20 AM   #20
flamingbig10
6.0 powered square
flamingbig10's Avatar
the middle grade ever start don't remember the CCA
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 12-15-2010, 01:33 AM   #21
bmchevy1979
bmchevy1979's Avatar
I also have a walmart battery it is a MAXX75S I think it is about 770 cranking amps and it turned my 400sb with ease
<Brandon>
1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works.
1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15
81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in
1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096
1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195
bmchevy1979 is offline   Reply With Quote
Old 12-15-2010, 05:13 PM   #22
marksmak
Optima yellow top
marksmak is offline   Reply With Quote
