Re: Need help with removing Front End Clip
I did mine last weekend. (1980 SWB)
Here were my steps: EDIT (My hood was aready off the truck!) 1. disconnect battery 2. disconnect radiator hoses and trans cooler lines from radiator. 3. disconnect AC Hoses that pass thru the core support 4. disconnect the front wiring harness from the back of the fuse block on the firewall 5. disconnect grounding wire connecting core support to the frame 6. disconnect vacuum line to canisters ect (including fuel tank vent lines) 7. attached four heavy straps from the top insides of the fenders to my wench (only had girlfriend to help me!) 8. removed two large bolts holding the core support to the frame 9. removed one bolt on each fender inside the door jam 10. removed one bolt on each fender under the truck, near door jam 11. removed two bolts on each fender inside the fender well 12. removed right side tire (to clear factory AC unit) (may not be necessary but being careful!) 13. lifted clip up and forward while checking for obstructions, or connected parts! 14. lowered clip onto dolly Wrote from memory so help me out folks if I left anything out. Jonas, sounds like you already had all this, but thought it might help someone searching for the same topic!
Allengator Outta the Blue (my band - available for hire in the DFW area!) 1980 Chevy SWB Pickup (build thread) 1951 Chevy Sedan Delivery 2004 Chevy Tahoe Z71 2011 Harley Davidson Street Glide 2018 Silverado Z71 Crew Cab Last edited by allengator; 12-14-2010 at 11:26 AM. |
| Bookmarks |
