Old 12-13-2010, 07:10 PM   #1
mooseknuckles
mooseknuckles's Avatar
what size trailer fenders?
I'm going to make some inner fenders for the front of my truck out of trailer fenders and was wondering what size to use? I can get a 32" x 10 3/4"w x 15" h will this work?
mooseknuckles is offline   Reply With Quote
Old 12-13-2010, 10:54 PM   #2
muthstryker
muthstryker's Avatar
Re: what size trailer fenders?
I found that a 36" trailer fender is a better fit, it spands the entire length of the wheel well opening.. these are the ones I bought. I bought 2 of each just to be safe.
http://www.kmtparts.com/catalog.asp?...showprevnext=1
muthstryker is offline   Reply With Quote
Old 12-13-2010, 11:14 PM   #3
mooseknuckles
thanks
Old 12-14-2010, 02:01 PM   #4
jitteryguy
GoatLube Experss
jitteryguy's Avatar
did you get yours yet ? at that price I wounder about the quality/metal , If their decent I will def go this rout ! I was gonna make mine outa inner fenders from a donor bed but that 13X36 would be much better .
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 12-14-2010, 02:25 PM   #5
mooseknuckles
didn't buy them yet, but there about $20 a piece here 16ga.
Old 12-14-2010, 02:32 PM   #6
muthstryker
I havent gotten them yet, talked to a guy there. They are the only ones I found online that werent galvanized.
Old 12-14-2010, 02:42 PM   #7
dv8customs
dv8customs's Avatar
Check local farm supply stores if they have them in your area. Around here you can get them at Atwoods or Tractor Supply.
dv8customs is offline   Reply With Quote
Old 12-14-2010, 03:07 PM   #8
jitteryguy
GoatLube Experss
jitteryguy's Avatar
I reckon for that price I'll get a set . says 16 gauge so they should be OK.
'85 1/2 ton CCSB
'92 S10 350/350
Old 12-15-2010, 02:00 AM   #9
pig rig
pig rig's Avatar
also six robblees in everett they have them in stock
http://www.sixrobblees.com/AboutUs.aspx
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette
http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG
pig rig is offline   Reply With Quote
Old 02-05-2014, 07:27 PM   #10
C10_Dreamin
C10_Dreamin's Avatar
Moose! Did you ever make these?
C10_Dreamin is offline   Reply With Quote
Old 02-05-2014, 08:23 PM   #11
mooseknuckles
I bought the 36" ones but never got around to making them....every time I would give it a go, I would test fit them and see that the round trailer fender doesn't fit the c10's square fender.....it would work better if you had to tub the firewall for bigger wheels and tires, but I don't need to....and I also didn't want run the fender straight into the firewall.....think I'll eventually go with some slosh tub's.
Old 02-05-2014, 08:36 PM   #12
C10_Dreamin
Slosh seems like the way to go, do you have a VintageAir a/c system installed?
Old 02-05-2014, 09:01 PM   #13
mooseknuckles
no, not yet. I was planning on getting the vintage air frontrunner pulley set up and then the a/c, but it's hard to say.
Old 02-05-2014, 09:15 PM   #14
C10_Dreamin
I'm worried about the hose clearance where they go into the firewall on the pass. side. It looks really tight in there, 67sheby mentioned that they'd work if I got some 90 degree hoses where they connect. I'm using the plate that came with the VintageAir system.
Old 02-05-2014, 09:35 PM   #15
mooseknuckles
yeah...I've no idea...I know I want all the hoses hidden, guess I'll cross that bridge when I get to it....
