Old 12-14-2010, 12:48 AM   #1
Gadoozle
God Bless America
Gadoozle's Avatar
Air Bag Suspension
Hi Everyone,
I'm 15 and I'm new to the truck scene, so forgive me if this is a stupid question. What exactly is air bag suspension? What does it do? What are its benefits and problems? How does it work? I'm looking to lower my '72, and I think this may be the route I want to take. I don't want it to touch the ground, but I want it low.
Thanks!
1972 Chevrolet Custom/10...my first truck and first project.
Semper Fidelis
Gadoozle is offline   Reply With Quote
Old 12-14-2010, 01:15 AM   #2
BarryB
BarryB's Avatar
Re: Air Bag Suspension
Basically an air bag, or Bagged truck has the coil springs removed and air bags put in there place. Its more involved than that but hopefully that will give you an idea. There are several threads on here with guys installing or just showing there bagged trucks. I plan on bagging my truck when the time comes.
When you have air bags with somekind of air compressor, tank, and controls you can raise and lower your truck. For example drive it to a show raised up, when you get there you can let the air out to drop your truck.
I'm sure more will post the pics or comments. thats my input .
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 12-14-2010, 01:30 AM   #3
Gadoozle
God Bless America
Gadoozle's Avatar
Thanks BarryB. Would you suggest putting air bags in a truck? Does raising and lowering screw up your alignment?
Semper Fidelis
Old 12-14-2010, 01:49 AM   #4
Slick67
Sofa King Crazy!!
Slick67's Avatar
It keeps the alignment pretty well. You will have to have it aligned at "ride height" then lower it when you get to where you are going. Driving it lowered is costly if it is not done correctly. Check out the Suspension section in the forum and you will have a better response to all of your questions! Slick67
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 12-14-2010, 01:51 AM   #5
BarryB
BarryB's Avatar
This all depends on what you in vision for your truck. anytime you raise and lower your truck there are alignment issues. You have drive shaft angle issues. This is why I plan driving mine while in the raised position, and only lower it when I'm parked or moving slowly.
Two rules in life.
Old 12-14-2010, 01:54 AM   #6
gonzo6869
Cops, ha, catch me if you can!
gonzo6869's Avatar
An air bag system is something that can be done several different ways depending on your budget. If you just want to go with your minimal setup; Airbags, Compressor, Tank and other misc. it could cost you somewhere around $1000 up. (Depending on what type of parts you get) This setup will give you a decent drop but you'll be riding on old suspension parts. Now if budget is not problem (who am I kidding, it always is), then you can go with a setup that I am looking at getting. Brand new control arms (upper and lower), drop spindles, airbags, a completely new rear suspension (trailing arms and such, the bolt on kit that many vendors sell) and some sort of air management system along with a leveling system, this can run just a little bit more, about $5,000 on up. With this setup you'll not be draggin on the ground, but you'll be getting all the benefits of having a bagged truck; a complete new suspension that will be able to outperform most other suspension setups. It’s a lot of money, but if you do it right the first time you will never have to do it again. A properly installed and maintained airbag system should outlast your truck. (I think I said too much) You are 15, I don't think you'll have deep enough pockets to do this all at once, if you do, but save up and start with a good compressor, tank and valves, ones that you can continue to us as you go on. Then just start doing it one step at a time, go with just the airbags and with time and saving some money you can get the other parts and just do the upgrades one at a time. If you can't afford something, don't go cheap, wait till you can afford it.
Well I said too much. I know you were only asking what an airbag setup was, maybe a little too much info for you, but its honest.
72 C-10 Stepper
350/TH350
3.73 in the back
Edelbrock intake and Carb
Hooker Comp Headers
275/60R15 on Rallies
gonzo6869 is offline   Reply With Quote
Old 12-14-2010, 02:47 AM   #7
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
All of that is good advice!
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 12-14-2010, 02:48 AM   #8
Jacfourteen
Another benefit of having an air suspension is that you can have a lowered truck and still use it to haul with, when you load it down you just pump up the bags and go.
Old 12-14-2010, 12:54 PM   #9
Gadoozle
God Bless America
Gadoozle's Avatar
Good point...but after my truck is restored, I probably won't use it for hauling. Can you raise your truck up again after you lower it?
Semper Fidelis
Old 12-14-2010, 02:43 PM   #10
Troyz R Us
Troyz R Us's Avatar
^ Absolutely!...at the touch of a switch or button you can raise it back up. The (air) compressor on your truck would supply the air tank with air. With a switch, you can control how much air is let in or out of the air bags. Which will raise or lower your truck. So you can raise and lower your truck until your air tank runs out of air. Tank gets low on air, your compressor kicks on and refills it. That's a pretty basic outline. Depending on what you want to do with it, you can have many different configurations, several switches, multiple air tanks, multiple compressors, etc.
Go to Youtube and search for "bagged trucks"...see it in action.
Troyz R Us is offline   Reply With Quote
Old 12-14-2010, 03:23 PM   #11
Gadoozle
God Bless America
Gadoozle's Avatar
Thanks man! I didn't realize the operation of lowering and raising was so easy. I've been told that driving your truck while it's low is a bad idea...Why is this?
Semper Fidelis
Old 12-14-2010, 05:24 PM   #12
67chevemall
67chevemall's Avatar
Rear is a breeze with coil wishbone suspension...the front you need drop spindles and steel plates for the top of the bags and steel cups for the bottom of the bags.
One can use shrader valves or get valves, pumps, and compressers which add$$ up quick.
The suicidedoor.com kit is a great start.
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 12-14-2010, 06:24 PM   #13
Jacfourteen
Your alignment changes as you change height, so you want to pick a height that will allow you to clear obstacles (speed bumps, pot holes, etc) and that you like how it looks. Then you take it in and get it aligned and write down the pressure for each bag, then when you're driving you set it to that pressure which will mean it's the same height. That way it is aligned correctly and won't wear tires/parts. If your just cruising through the HS parking lot or whatever it wouldn't hurt to ride with it low, its more about going longer distances. Hope this makes sense and helps you out.
Old 12-15-2010, 01:10 PM   #14
Gadoozle
God Bless America
Gadoozle's Avatar
Thanks, man. It does help me out. I mostly understand what bags are now. The only issue is I haven't found a thread that shows step by step how to install them.....Does anyone know of a thread that explains how to bag a truck?
Semper Fidelis
