![]() Join Date: Sep 2009
power steering box
can shttp://67-72chevytrucks.com/vboard/attachment.php?attachmentid=668388&stc=1&d=1292365695ome one identify this power steering box--it is on a 64 gmc i don't know what i did but here is the question-what steering box is this i am trying to find out so i can order the right parts to install my ididit column thanks
Re: power steering box
looks alot like the one i put in mine, it was out of a 78 chevy 2wd. for about 50 bucks you can get a steering column out of a 93 s-10 and put that in there and save you around 300 bucks, thats what i did.
That gear box is called a saginaw found on most older chevy or gmc
60-66 Nut
All I can tell you from the pic is that it is a '69-'87 GM truck power steering box. The '69-'80-'81 boxes had inverted flare fittings for the hoses, and the '81-'87's had a metric sized fitting with an O-ring. Then there are 2 or 3 different sizes/splines for the coupler to the steering column. It looks like you already have the coupler, so that wouldn't be an issue for you, unless you are going to change it to a universal joint or something else.
#5 | |
... do you have pics? Is there a thread on this swap?
![]() 66 Chevy C10 LWB ![]() |
