Old 12-15-2010, 08:57 PM   #9
99 to Life
99 to Life's Avatar
Re: Proportioning Valve
I thought I had proportioning valve problems, as I had all new everything and I couldn't get any fluid to my lines. I had other problems. But from what I can gather with the prop valve is, it is better to use one than not. For one, it would be nice to know when you have no brake pressure and two it will distribute fluid to one end or the other in event of a leak.
I am sure they can go bad, there are some little pieces in there. But I am pretty sure your pin should be sticking out not in.
I am far from an expert on these though.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
bleeding, brakes, proportioning, valve
