Old 12-14-2010, 11:42 PM   #1
Scott26
Scott26's Avatar
How hard is a Carb to TBI conversion?
im thinking about getting rid of the quadrajet and puting a tbi motor in. Would i have to buy a 87 and up crate engine.or could i buy the painless wiring conversion kit and then get a throttle body off a donor truck? Is this to hard of a job for a average backyard machanic?.
1986 GMC Sierra Classic 4X4
Scott26 is offline   Reply With Quote
Old 12-15-2010, 12:13 AM   #2
wyattglock
wyattglock's Avatar
Re: How hard is a Carb to TBI conversion?
If you are not looking for a stock style 2 barrel setup, there are a couple of different aftermarket 4 barrel tbi units. I personally havent used any of them, but I am sure some of the guys on here could chime in with some advice. I know Holley, FAST, Accel, and Edelbrock all have complete systems. If you are working on a tighter budget than that, a donor vehicle of at least a 1987 would get you all you needed.
wyattglock is offline   Reply With Quote
Old 12-15-2010, 12:34 AM   #3
lindstromjd
Gentleman Jim owner x2
lindstromjd's Avatar
Wiring harness and ECU would get you what you wanted. You'd also have to get an intake adapter, because of the way the TBI's bolt in. The TBI intake requires heads with top-style valve cover bolts, and the carb intakes are usually side-style.
1975 GMC Gentleman Jim #1
-357 / 700r4
1975 GMC Gentleman Jim #2
-350 / TH350
lindstromjd is offline   Reply With Quote
Old 12-15-2010, 01:00 AM   #4
355bullet
355bullet's Avatar
check it out, here are some kits.
my friend adapted the tbi for his v8 jeep. And its an amc engine
http://www.affordable-fuel-injection.com/
355bullet is offline   Reply With Quote
Old 12-15-2010, 09:11 AM   #5
pooods
Stick with the Q-jet over a stock TBI system. The only advantage I have ever noticed is better cold weather starting and possibly a MPG improvement. However, the Q-jet is easy to work on and when in good condition it will start good and have more power than any TBI I have driven. The TBI just dies about 4k RPM's. Not having all the sensors and problems coming along with them is priceless IMO.
The Holley TBI is a better performer. Not cheap but a nice system. Tunable and can adapt to future mods well. Still more aggravating to work on than a carb though.
John M. Ayers
pooods is offline   Reply With Quote
Old 12-15-2010, 10:13 AM   #6
Jonboy
Slots go on anything!
I am in the middle of doing this very swap on my '74. A buddy of mine is upgrading to an LS in his '87, so I decided to run his old TBI stuff vs. going LS. I found a lot of good tech here: http://www.binderplanet.com/forums/f...splay.php?f=75 , and here: http://67-72chevytrucks.com/vboard/s...d.php?t=352321 .
I used the wiring harness from fuel injection connection. It is all new, and was relatively inexpensive, at $245. It is labeled, and it is a really nice harness. Robert has answered any questions I have had pretty quickly, too. Their site is www.fuelinjectionconnection.com . I also had teh luxury of having an '87 parts truck, but the engine, trans, ecm, and harness were long gone. I pulled the fuel tank, but with TBI you could probably either run an external pump, or just buy a new tank & sending unit. The lines in my parts truck weren't all that great, so it wasn't much of a bonus there. You can get most of what you need from a 87-up Suburban or Blazer, too. Not sure about your area, but they are fairly plentiful in the pick a parts here.
The binderplanet site is pretty cool in that a lot of teh guys there are adapting the GM TBI for use on their existing IH engines. Compared to that, we have it easy. I feel like I wussed out buying a new harness compared to those guys....
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 12-15-2010, 11:53 AM   #7
355bullet
355bullet's Avatar
here is the new fast unit. ive seen this installed, its clean. looks simple too
http://www.fuelairspark.com/ezefi/default.asp
Old 12-16-2010, 04:22 AM   #8
lindstromjd
I know firsthand just how bad it is to have a GM system on an IH engine. (I have 2 International Scouts right now). It's NOT a fun time going through all the "spaghetti" (excess wires) and cutting out everything you don't actually need to make the engine run. But it does turn out really nice in the end. Really, it just takes a lot of patience and some practical know-how to make it all work. Stick to the instructions.
-357 / 700r4
-350 / TH350
Old 12-16-2010, 10:17 AM   #9
Jonboy
That is a lot of the reason I went with the FIC harness. I know I could build my own, I just don't have the time to do it.
