Old 12-16-2010, 02:01 PM   #12
sandorjoben
sandorjoben's Avatar
Re: More heat please
I had the same problem, and my thermostat had failed halfway open, replace your thermostat and put a baffle ahead of your radiator. I pulled my grill off and used a piece of foam indoor carpet underpadding, just make sure you you don't block flow through the radiator too much, because your temp gauge will read like your engine is overheating. The piece of padding I cut goes ahead of the radiator and covers the whole front of the radiator but has two 6" x 12" holes cut on either side to allow enough air through).
Dave
87 GMC V15 in profile photo sold 2013
99 Chev Silverado 2500 5.3 reg cab long bed
sandorjoben is offline   Reply With Quote
