Old 12-16-2010, 02:19 AM   #1
mwilliams5891
my truck accelerates when i push in the clutch
So yeah my 69 c/10 accels. when i push in my clutch and it will go down MOST of the time if i rev the engine...so any help would be nice.
By the way 250 CID with a Holley 390 CFM 4 barrel on it
-1969 C/10 Short Step soon to be Brand NEW Ls6/T56
-03 Mazda Protege 5
-WTB 1970 Chevelle project
mwilliams5891 is offline   Reply With Quote
Old 12-16-2010, 04:10 AM   #2
mwilliams5891
Re: my truck accelerates when i push in the clutch
anyone know why?
-03 Mazda Protege 5
Old 12-16-2010, 06:18 AM   #3
JimKshortstep4x4
It sounds like there is some movement of the engine. Can you have someone watch the engine when you depress the clutch?
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 12-16-2010, 08:52 AM   #4
70 shorty
Where's my beer?
70 shorty's Avatar
Could possibly the choke and/or fast idle be not completely releasing?
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam.
79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam.
'03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great
'08 Tahoe LTZ 4x4 155K
70 shorty is offline   Reply With Quote
Old 12-16-2010, 03:43 PM   #5
mwilliams5891
that is what i was thinking. since its an electric choke could it just not have enough power?
-03 Mazda Protege 5
Old 12-16-2010, 03:44 PM   #6
mwilliams5891
Jim
so what should i look for exactly? i dont mean to sound like a smart a** just wondering
-03 Mazda Protege 5
Old 12-16-2010, 03:50 PM   #7
splehigh
splehigh's Avatar
Watch and see if your motor is rocking side to side when you press the clutch or rev the motor. If it does, you may need new motor mounts.
I'm not sure why the motor would move when you press the clutch though...
splehigh is offline   Reply With Quote
Old 12-16-2010, 03:53 PM   #8
mwilliams5891
ok will do
-03 Mazda Protege 5
Old 12-16-2010, 05:12 PM   #9
mwilliams5891
ttt
-03 Mazda Protege 5
Old 12-16-2010, 05:44 PM   #10
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I would suggest you also look at the linkage/cable for the throttle.It could be hung on the clutch linkage.Or the wiring for the electric choke could be shorting on the linkage.A fast idle solenoid could cause this also if it were shorting or maybe misadjusted.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 12-16-2010, 05:45 PM   #11
CCCC
CCCC's Avatar
There is minimal info here - and I am not familiar with the inline 6 lever/linkage setup for clutch and accelerator operation, but the first logical thought seems to be that there is some minor interplay between the two. Just a suggestion - observe the under-hood operation of the clutch linkage and see if in its travel it is in some way touching or engaging the accelerator linkage. Hope this helps.
CCCC
67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison
Moved but still in the family
70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350
Recently sent to new homes
72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp
CCCC is offline   Reply With Quote
Old 12-16-2010, 05:48 PM   #12
Gobbles
Gobbles's Avatar
What do I do if my whole truck shakes
Trevor
"You already said spite"
Gobbles is offline   Reply With Quote
Old 12-16-2010, 06:07 PM   #13
don t. - 72gmc
Play Chuck Berry music(smart a$$ grin).
don t. - 72gmc is offline   Reply With Quote
Old 12-16-2010, 06:12 PM   #14
Allensracing
Allensracing's Avatar
is this happening while parked and in neutral with the foot off the accelerator pedal completely?
Allensracing is offline   Reply With Quote
Old 12-16-2010, 07:18 PM   #15
mwilliams5891
yes this will happen if i stop at a stop sign or im slowing down to stop or pretty much anytime i engage the clutch.
-03 Mazda Protege 5
Old 12-16-2010, 07:20 PM   #16
mwilliams5891
I will observe but I am almost 100% nothing is touching or anything like that. i could be wrong but i am pretty sure.
what kind of info do you guys need? I really said everything that happens...so I dont know what else to provide so you guys can help me sort out this problem
-03 Mazda Protege 5
Old 12-16-2010, 07:20 PM   #17
mwilliams5891
what does a fast idle solenoid look like?
-03 Mazda Protege 5
Old 12-16-2010, 07:21 PM   #18
Allensracing
here is what I would like you to try. park the truck. hold your foot on the brake. put the truck in neutral. push the clutch in and let it out. does the RPM change when you do this?
Old 12-16-2010, 07:24 PM   #19
mwilliams5891
I will go do that right now
I love laptops
-03 Mazda Protege 5
Old 12-16-2010, 07:28 PM   #20
BAGNDRAGIT
Just Not Low Enough!
BAGNDRAGIT's Avatar
what is the most recent repair right BEFORE this issue started?
is your carb adjusted properly, possibly when you release the load of the drivetrain via the clutch you are letting the motor return to its set idle speed... just a thought.
NEED ELECTRICAL HELP? ASK ME!
67-72 Full Wiring Diagrams
Lots Of Info, TAKE A LOOK
1967 Chevy C-10 Shortbox Bagged 327 4spd
Previous:
1971 Chevy C-10 Short Sep I6 Auto (Traded)
1973 Chevy C-20 *THE REDNECK BATTLE TRUCK*
2001 Chevy Silverado 2Dr 5.3L Shortbox. R.I.P.
1969 Volkswagen Bug
This is my first meeting, I have a horsepower problem.
BAGNDRAGIT is offline   Reply With Quote
Old 12-16-2010, 08:42 PM   #21
cleszkie
cleszkie's Avatar
I had a similar problem in an old jeep I had. Every time the engine was under and increased load (rolled up to a rock or log), the engine rpm would go up. Push in the clutch and rpms would drop off. Turned out to be wasted engine mounts. When the engine was under load, it twisted in the mounts. This would stretch the throttle cable between the carb and firewall, opening the throttle plates and stroking the accelerator pump. Check your mounts.
cleszkie is offline   Reply With Quote
Old 12-17-2010, 08:15 AM   #22
splehigh
splehigh's Avatar
LOL
Old 12-17-2010, 10:54 AM   #23
dadsworktruck
Check the bellhousing bolts, make sure all of them are tight so that the engine don't move foward as the clucth is being depressed, wouldnt take much to affect the 69's rod style throttle arrangement..just a thought...
dadsworktruck is offline   Reply With Quote
