Old 12-17-2010, 12:39 PM   #1
SS Delux
SS Delux's Avatar
Blazer and Suburban bumper on a truck
do you guys and gals out there know the difference between a blazer / suburban sport bumper vs. a truck sport bumper and do the brackets fit ?
SS Delux is offline   Reply With Quote
Old 12-17-2010, 01:46 PM   #2
SCOTI
SCOTI's Avatar
Re: Blazer and Suburban bumper on a truck
They're the same. Blazers & trucks share similar brackets (inner & outer). Burbs use the same outers but no inners as the frame rail bolts directly to the bumper.
Vans also use a very similar bumper but the bolt holes are in a slightly different location for the inners.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-17-2010, 01:55 PM   #3
jitteryguy
GoatLube Experss
jitteryguy's Avatar
'81 to '91 Sub/Blazer does have a short inner bracket. a plate can be made to go from the truck frame to the bumper bracket, but most poeple just use the outer bracket to mount it .
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 12-17-2010, 02:16 PM   #4
SCOTI
SCOTI's Avatar
True. The rear is much like the front short inner brackets (81-91 only).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
