Why doesn't my hood close right?
On my 67, the hood does not go down all the way in the back. I can push it down with my hand after it's closed. Is this normal or is something worn out?
Re: Why doesn't my hood close right?
It needs some adjusting or also, that is one of the main signs that the hinges are worn out.
72 Cheyenne Super 80 Silverado Blazer 2wd Last edited by sameyrasmea72; 12-17-2010 at 04:28 PM. |
its all about the +6 inches
worn springs will cause this, as will worn rivit holes.
If you have nice paint, take steps to prevent paint damage. Open hood. Loosen the bolts that hold the hinge to the fenders. have an assistant push the hood open a little further. Tighten the bolts as the helper keeps it a tic further. SLOWLY lower the hood. Keep an eye on the rear of the hood, it may rub on the cowl. If that happens, loosen the 4 bolts that hold the hood to the hinge and slide the hood forward a bit. rinse and repeat some cars not for use with some sets actual results may vary side effects may include diarrhea or constipation ![]() Last edited by Longhorn Man; 12-17-2010 at 08:56 PM. |
72 GMC
nice disclaimer
I had several of these trucks with the same problem. Someone on this site finally helped me fix it. Open the hood, loosen the hood hinge bolts on the fender and have someone push up on the hood from the front until you see the hinges lower in the back. tighten and check it. It worked for me!
67 Stepside Atomic Orange Fastburn 385 TH350 The wheels are fronts are 255-45-18 with 5" bs. 18x8 wheel rears are 295-45-20 with 5" bs. 20x10 wheel (barely fit) Budget: A method for going broke methodically. You only live once! |
yeah... what he said!
72 GMC
isn't that what you said ?
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
Open the hood. Now move the front of the hood from left to right while watching the hinges. If the hinges move around on the rivetts, the hinges are warn out and the hinges need replacing. Tipping the back of the hinge back with warn out hinges is a temporary fix at best. The hinge will eventualy bend or come apart, and always at the most innopertune time, doing dammage to your new paint. The springs have nothing to do with pulling the rear of the hood down, they pop the hood open, assist in the lifting of the hood and hold the hood open. New GM hinges are still availible, so I would buy a new set now while you can. (If yours are warn out) The will be discontinued soon. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
Ex-Minitrucker
Why are the left side hinges $36 more than the right side? Just asking.
68 C10 LWB 292 4spd 68 C10 LWB 250 3spd |
GM bases their prices on the sales of a part. If a left side sells more than the right, then the left sells for less. They are that way on virtualy all of their parts. WES
![]() Join Date: Aug 2010
Mine was the same way. All I had to do was loosen the hinge mounting bolts (to the fender) and push up on the front of the hood while it's open. Then, tighten the bolts while someone holds it up. This will push down on the the back of the hinge and make the hood sit lower.
67 5.3L Build |
![]() Join Date: Feb 2010
longhorn man that is a good one conctipation and diahera
