Old 12-19-2010, 09:21 PM   #1
Raymond Thompson
Raymond Thompson's Avatar
Electrical Help Please:
I just installed a factory tach in my 1971 Chevy Cheyenne...the complete kit from Classic Trucks. It included a new printed circuit board, as well as new cans and bezel. Now my turn signals and high beam indicator light up when I turn on the parking lights. They still work when I turn on a turn signal but I don't think they are supposed to be lit dimly when the parking lights or headlights are on. Is this a loss of ground issue or do I need to move some of the wires in the dash wire connector. Anyone had this problem before, and can tell me what do do?
As information, I also installed a cruise control, new A/C system and new radio, under dash lights, new dome light and two amps and a equalizer. They all seem to be working fine.
Raymond
Raymond Thompson is offline   Reply With Quote
Old 12-19-2010, 10:18 PM   #2
gkesseru
gkesseru's Avatar
Re: Electrical Help Please:
Did you have an idiot light panel before? The ground and some other wires are different.
72 Fleet (died)
78 Step (sold)
55 Step named Fred (sold)
00 F150
68 Step (named El Scorcho by PO)
Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932
gkesseru is offline   Reply With Quote
Old 12-19-2010, 10:26 PM   #3
cdowns
cdowns's Avatar
there are supposed to b small cardboard tubes shielding and isolating the light bulbs// not having them in place causes the washover from the other lights
Old 12-19-2010, 11:03 PM   #4
legendary
legendary's Avatar
Sounds accurate...
Best Regards,
Leon
1970 C/10 LWB Cummins Turbo - Build in Progress
Many other toys as well...
legendary is offline   Reply With Quote
Old 12-20-2010, 01:37 PM   #5
Raymond Thompson
Those are all good suggestions... however the truck has a gauge dash to start with and the cardboard tubes are securely in place. I don't think it is bleeding light. The turn signal lights and the headlight highbeam light on the dash panel are getting power from somewhere when they shouldn't be.
On a previous restoration I encountered the problem of converting a NON-gauge dash to one with gauges and had to move wires in the connector block to make the turn signals work and had a similar problem. But I didn't think that just adding a tach would make it necessary to move any of the other wires. The tach is powered with its own wire connected to the back and does not use the circuit board...Any other suggestions?
Old 12-20-2010, 02:36 PM   #6
haysonj
haysonj's Avatar
Mine was doing something similar except it was only the turn lights, I ended up finding a shorted wire in the tail light section
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 12-20-2010, 03:10 PM   #7
cdowns
cdowns's Avatar
there was a factory ground wire from the firewall to the guage panel
Old 12-20-2010, 06:51 PM   #8
Raymond Thompson
OK Thanks... It's a missing ground or a short. I'll run a wire from known ground to the can around the back of the dash cluster to see if that fixes the problem. If not, I'll look for a problem in the front turn signal... I had a problem with the right front turn signal lamp holder once before.
I appreciate the help.
Raymond
PS: What does a "junior member" signify??? I noticed that I am earmarked as a junior member???
Old 12-20-2010, 06:56 PM   #9
cdowns
cdowns's Avatar
junior member means at meetings and gettogethers you get to buy the beer
Old 12-20-2010, 07:18 PM   #10
john
member #16
john's Avatar
Yes check the turn signals. My bulb sockets were loose in the housings and lost their ground. My turn signal indicaters were also lit with the lights on, I dont remember the high beam coming on.
john is offline   Reply With Quote
Old 12-20-2010, 07:30 PM   #11
68 Stepside
huh?
68 Stepside's Avatar
I ran into the same issue when I didn't have a good dash ground. Neat things would happen when I hit bumps, sometimes indicator lights would come on, sometimes the dash lights would go out, etc.
I THINK there is a clip on the factory wiring harness that clips onto the gauge panel, or maybe it goes somewhere else...can't recall
I would run a simple wire from a known good ground to a screw on the back of the gauge cluster.
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
