Old 12-20-2010, 03:06 PM   #1
manimal
manimal's Avatar
crewcab question?
What is the difference in a 3/4t and 1t single rear wheel crewcab? Is it just the springs? I know they use the same frame,rear axle and front brakes. Remember this is NOT a dually. Thanks
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 12-20-2010, 03:12 PM   #2
babyJay
Arrived on a Pale Horse
babyJay's Avatar
Re: crewcab question?
I think something with the ball joints and spindles are different. I found this out shopping for drop spindles, I'll be watching the thread b/c I've been wondering the same thing.
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 12-20-2010, 04:16 PM   #3
ghettoluxury
ghettoluxury's Avatar
The frame is different, as well as the spring pad width and the front brakes.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 12-20-2010, 04:36 PM   #4
Prerunner1982
Prerunner1982's Avatar
What axles do they have? I thought the 3/4 ton had a Semi-Floating 14 bolt and the 1 ton had a Full Floating 14 bolt.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 12-20-2010, 05:18 PM   #5
rideair
If it's a 4x4 the front is a Dana 60 on the 1-ton and a Dana 44 on the 3/4 ton.
Paul Waddell
Front Royal, VA
1986 K30 Crewcab, SRW
rideair is offline   Reply With Quote
Old 12-20-2010, 05:24 PM   #6
manimal
manimal's Avatar
I could have sworn they use the same frame on the crewcab. They both use the full floater. Maybe the spring perches are different,wider on the 1t. and it's not 4wd.
-Lance
Old 12-20-2010, 09:36 PM   #7
DetroitDan
DetroitDan's Avatar
I thought the spring hangers were mounted differently too, but its been a long time since I knew what I was talking about. Didnt something have the springs mounted under the framerails instead of beside them, with more inboard pads? IDK, my 82 crewcab&chassis (just made that up) has them outside the framerails just like my 97.
1982 Chevy K30 CCLB fleetside. Formerly a cab and chassis, now a fleetside dually with the rear wheels tucked underneath. 454/th400/np205/C14/D60, 6/4 inch LIFT, not drop.
DetroitDan is offline   Reply With Quote
Old 12-20-2010, 09:42 PM   #8
Walts_restoration
Real Projects never die
Walts_restoration's Avatar
i always heard they used the same frames on the crew cabs, never compared the 2 so other than that i cant help ya.
Ill put it this way, ive got a few lawn ornaments
My name tag says Ryan
KansasTwister On other forums
Walts_restoration is offline   Reply With Quote
Old 12-21-2010, 02:27 AM   #9
pig rig
pig rig's Avatar
the only thing Ive found different on the SRW CREW CABS is the number of leafs in the rear spring pack and the spindles and the differance in the spendles is the way the caliper mounts and the way the brake line hooks to the caliper and most 3/4t didnt come with hydroboost brakes
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette
http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG
pig rig is offline   Reply With Quote
Old 12-21-2010, 03:45 AM   #10
ghettoluxury
Yes they both use a full float 14 bolt but the hangers and purches on the 1 ton are different. In the later years a semi float was a option but I have never seen one under a Crew. As pigrig said Hydro boost is an option and a must have IMO.
Old 12-21-2010, 03:58 AM   #11
ghettoluxury
3/4 ton caliper
1 ton caliper
Old 12-21-2010, 07:02 AM   #12
GM72K10
Next!
GM72K10's Avatar
Frames should be the same
86 K30 CUCV M1028A1
86 K30 CUCV M1028a2 dually
86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump
More square bodies and CUCVs than I care to admit to
2020 Silverado K3500HD Work truck
GM72K10 is offline   Reply With Quote
Old 12-21-2010, 01:49 PM   #13
manimal
manimal's Avatar
Yep, the frames are the same. Thanks!
-Lance
