Old 12-20-2010, 04:48 PM   #1
jakeblues652
jakeblues652's Avatar
Re: gear ratio ?
yeah, i just thought 90 bucks was a little crazy...and i was always told to never reuse the gaskets, and use gasket sealer sparingly on them just for the best seal. but it changes from person to person i guess. and this truck, i want to cut as few corners as possible.
1967 K-10 4x4 with a 3" lift and 35" BFG mud terrains
Originally Posted by Dan in Pasadena View Post
Did you figure out how to fix it?...I mean with other than a BFH?!
want to see some slow progress on my truck? http://67-72chevytrucks.com/vboard/s...d.php?t=436560 <-click there
jakeblues652 is offline   Reply With Quote
Old 12-20-2010, 04:50 PM   #2
Redcap
Re: gear ratio ?
Use RTV instead of gaskets and get a decent quality dino oil.
Redcap is offline   Reply With Quote
Old 12-20-2010, 05:05 PM   #3
bfay17
Young Gun
bfay17's Avatar
Re: gear ratio ?
I completely understand not wanting to cut corners. If you use the black rtv you dont even need a gasket it will set it up very nicely. I just use a 1/4 to 3/16 thick bead around the whole cover and i havent had one leak yet. Again im not saying its the only way to do it.
bfay17 is offline   Reply With Quote
