Old 12-19-2010, 06:30 PM   #1
SilveradoDude
Question Sheared seat belt bolts, need advice
I completely sheared the heads of several of the seat belt bolts when removing my carpet. I didn't want to apply any heat to them as they were directly above my gas tanks. I did apply plenty of penetrating lube but it didn't help much. How should I go about removing the rest of what is left of these bolts? Any help is appreciated. Thanks.
SilveradoDude is offline   Reply With Quote
Old 12-19-2010, 06:42 PM   #2
nbpro
Re: Sheared seat belt bolts, need advice
Smack it with a hammer several times. Get a good pair of vice grips, maybe that will work. Other than that, I have no idea.
nbpro is offline   Reply With Quote
Old 12-19-2010, 07:33 PM   #3
bikes&bowties
bikes&bowties's Avatar
E-Z out? I would take a little propane torch to it.. it wont get hot enough to cause issues with the fuel tank
bikes&bowties is offline   Reply With Quote
Old 12-19-2010, 07:58 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Don't use an EZ out. If the large bolt was so seized it broke off, the smaller EZ out is sure to break off, leaving you a much bigger problem.
Drop a big nut onto the bolt stub sticking up and weld the nut to the bolt remains nice and hot. Let it cool and it will quite likely turn right out. The heat is the secret.
I did a tech article on this technique awhile back. I'll see if I can find it.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 12-19-2010, 08:01 PM   #5
S10Fan
Old Heap Driver
Originally Posted by tx firefighter View Post
don't use an ez out. If the large bolt was so seized it broke off, the smaller ez out is sure to break off, leaving you a much bigger problem.
I did a tech article on this technique awhile back. I'll see if i can find it.
x2
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 12-19-2010, 08:08 PM   #6
Tx Firefighter
Here is the thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=355839
Weld it nice and hot. The entire nut should be glowing dull red when you're through if you do it right. The heat wicks down into the threads and loosens er right up. Let er cool and twist it out.
Old 12-19-2010, 08:08 PM   #7
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
if that dont work drill tap and die set
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 12-19-2010, 08:09 PM   #8
russgt
russgt's Avatar
x3, mine did the same, welded on nut on to the remaining shank of the bolt underneath the truck and used a little heat.
70 stepside
76 blazer
86 Sierra Classic
20 Max Trailering 6.2 Crew
71 Nova SS
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634
russgt is offline   Reply With Quote
Old 12-20-2010, 01:43 PM   #9
Bullitt519
Yep this works great we do this all the time at the body shop i worked at esp on bolts damaged in wreaks...
1983 GMC SWB (Flood Rebuild Coming Soon)
1990 Nissan 240sx (Coiled And Rolled)
2001 Mustang Bullitt (Daily Beat)
Bullitt519 is offline   Reply With Quote
Old 12-20-2010, 07:00 PM   #10
SilveradoDude
Exclamation Re: Sheared seat belt bolts, need advice
Ok, I have never had a good experience with easy-outs and welding a nut to the top of the bolt is not an option because I do not have a welder and do not weld (I don't know why you think I would). So I see my other options are drilling it out in whole or in part, applying heat or using vice grips...or a combination of the group.
Old 12-20-2010, 07:05 PM   #11
old Rusty C10
vice grips will strip it.. drill tap and die
Bob
I hate cancer!!
Old 12-20-2010, 07:06 PM   #12
Tx Firefighter
A little testy aren't you ?
Old 12-20-2010, 07:36 PM   #13
SilveradoDude
Not testy just why you think everyone owns a welder is a little mystifying.
Old 12-20-2010, 07:49 PM   #14
joe231
joe231's Avatar
do you know someone with a welder?
usually anyone who works on much of anything either owns, or knows some one who owns a welder.
you can drill and tap it, but you must be perfectly centered and use the correct size bit.
the process Kevin mentioned it the quickest and easiest method I have found.
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 12-20-2010, 08:03 PM   #15
SilveradoDude
No.
Old 12-20-2010, 08:14 PM   #16
suprachrgd82
Farmtruck desciple
suprachrgd82's Avatar
If you go so much as a stump left, have a buddy with a wire-feed welder tack on a nut to the stumps. It won't create enough heat to cause worry about the gas tanks, but do cover in foil or wet cloth for safety. The heat from welding on the nuts will help free the threads, and the bolts can be removed with an ordinary socket.
Drilling for easy-outs runs the risk of damaging the original threads. Most folks consider this as a last resort.
suprachrgd82 is offline   Reply With Quote
Old 12-20-2010, 10:12 PM   #17
nbpro
read post 1 and 14 it looks like copy and paste ?
http://www.garagejournal.com/forum/s...ad.php?t=84732
Old 12-20-2010, 10:24 PM   #18
SilveradoDude
Originally Posted by nbpro View Post
read post 1 and 14 its looks like copy and paste ?
It looks pretty original to me.....
Old 12-20-2010, 10:34 PM   #19
nbpro
What I was referring to looks like the same question was asked on that website. And the same response when people suggested welding. Some have said vicegrips will strip the bolt out. Back in the early 80s I worked in an upholstery shop and this happened to me on more than one occasion. I found out what was making the bolt strip was all the crud and rust the bolt gets over the years. And hitting with a hammer before starting always allowed me to get the bolt out. But the bolts are big enough you can put vicegrips on them and they won't strip. Most of them don't go into the frame, and are countersunk. Here's a pic of standard seat belt bolts.
Old 12-20-2010, 11:12 PM   #20
nbpro
that would look pretty tool.... original to me.
Old 12-21-2010, 12:04 AM   #21
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
Dont hit the bolt downwards... guaranteed to poke a hole in the gas tank. I got mad and angry and did just that... poked a hole on the top of the tank.
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 12-21-2010, 12:12 AM   #22
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
Your best options have been laid out for you , And you are welcome to look for more answers. But the attitude will not help you here. I do understand not having a welder .
I think its safe to say that there bunches of people here that have welders (I have 3 ) So its a legit response .
I have been around here long enough to see that posts with your style of reply will be ignored by most .
I am assuming you were looking for help . Help is here , please stop shooting yourself in the foot with the quick answers
powerdriver 1958 is offline   Reply With Quote
Old 12-21-2010, 12:50 AM   #23
mr48chev
mr48chev's Avatar
TX Firefighter gave you the best answer and the one that will most likely work with the least hassle. And I would believe that would be pretty normal for 90% of the people on here to assume that a member on here either had a welder or had a friend who had one or knew of a shop that could do the work.
From my experience those bolts are pretty hard and won't drill out well.
Old 12-21-2010, 01:29 AM   #24
big_b
i have the same problem now. underneath the cab were the bolt protrudes through the floor, the threads of the bolt are rusty stopping the bolts (the annoying torx head) from turning. i am going to cut the rusty treads off with an angle grinder and hopefully be able to loosen the bolts from inside the cab with vise grips. if that fails i will weld a nut to the top of the bolt, inside the cab and turn that out. if that fails i will swear and curse at it and finger something else out!
big_b is offline   Reply With Quote
Old 12-21-2010, 01:36 AM   #25
willett
Another Day, Another Dollar
willett's Avatar
holy attitude....
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
