Old 06-24-2003, 11:08 AM   #1
4props
Sway bar Brackets
I'm looking for a set fo brackets to mount a sway bar on the front of a 71
1971 Cheyenne
4props is offline   Reply With Quote
Old 06-24-2003, 01:12 PM   #2
fatfords
fatfords's Avatar
If you are looking for the brackets that rivet to the frame, try your local GM dealer. I just bought a set a few months back for less than $10 per side. GM part number 6271375, AC part number 06271375. Beats the heck out of trying to get someone to cut them off a salvaged truck!
Good Luck,
Kent
'56 F-100 (w/all GM stuff)
Lookin' for another parts chaser!
'05 GMC crew cab
fatfords is offline   Reply With Quote
Old 06-24-2003, 01:17 PM   #3
4props
Thanks a lot for the part #. I'm going to go down to the Chevy house and check it out.
1971 Cheyenne
Old 06-24-2003, 03:34 PM   #4
Jwill41
Jwill41's Avatar
you will like your truck much better with the sway bar. Great improvement!
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline   Reply With Quote
Old 06-24-2003, 04:19 PM   #5
70 CST 4X4
Have A Nice Day!
70 CST 4X4's Avatar
You can try here too
ECE
About 19$ a pair and can get for lowered or stock height.
A friend got some for his lowered 69 and liked them.
1970 CST K10 350/350/205
Short Bed - Fleetside
Tach-Tilt-A/C-Tow Hooks
Front & Rear Disc Brakes
Front & Rear Posi 3.73 Gears
30 Gallon Stainless Fuel Tank
SOLD 01/18 !!!!!
2007 2500 HD Classic Crew Cab LT2 4X4 Duramax LBZ
70 CST 4X4 is offline   Reply With Quote
