#126 | |
I have a radical idea!
Re: Project 67 GMC custom 6.5 turbo diesel
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
#127 |
Parts Hunter
I just put a manifold pressure gauge on my truck today and did a little driving around with a deep half inch socket to adjust my turbo master. After a couple runs down the hiway and some cranking down on the nut, I'm pulling 9PSI at hard acceleration, and 5 PSI at cruising speed. From what I've read on the dieselplace forum those should still be pretty safe numbers, so I'm gonna drive it around like that for a while and see how that effects my fuel economy. Its has a very clear effect on my acceleration.
1968 Chevelle 300 DLX (350 4 speed) 1984 GMC 2500 6.2, 700r4 work truck 1967 GMC Custom (was 6.5 Turbo Diesel powered) My ebay Store: http://stores.ebay.com/The-Musclecar...3aFQ3aSTQQtZkm My website:http://themusclecarshop.net/ 1967 GMC 6.5 TD conversion build:http://67-72chevytrucks.com/vboard/s...d.php?t=290922 |
#128 | |
). If you don't turn your fuel up anymore, it shouldn't have any adverse effects on economy.
#129 |
Parts Hunter
When I got my reman pump I told the guy to turn the fuel flow all the way up. I found that will less boost the truck would chug (for lack of a better word) just before the shift from second to third around town (th400 trans). With the turbo turned up its smooth, and I'm finding that I have to back off the gas on the hiway at cruising speed, compared to what I was used to with the lower boost levels. So in theory I should be getting better than the 14.5 MPG that I was getting. I'll know after the first weekend in May as I have a swap meet to go to that is a 200 mile round trip.
#130 | |
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 04-18-2010 at 01:22 PM. |
#131 |
Parts Hunter
I have not yet seen water temp past 215 towing 7000 lb
s. However the truck has not seen ambient temps over 80 yet. We should be in the 90's in a month or so. With my set up if this radiator does not work out I'm going to look at aftermarket aluminum ones and an electric fan.
#132 |
Hey I saw your truck today at the Reno swap meet! My friend and I were trying to figure out what you had under the hood haha we both knew it was a diesel because of the intercooler. Its a small world running across this thread the very same day. My friend has a 72 blazer he wants to put a 6.5 in as well. I have seen your suburban on my way home from Sac City and have had my eye on it for a while haha, is it still for sale?
1964 C10 Shortened Shortbed Cammed LQ9 P&P 1967 C10 Trophy Truck BB 438 (soon to be worked on again) |
#133 |
Resident of Here
Whats your mileage?
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck
#134 | |
Parts Hunter
#135 |
Parts Hunter
No where near what I was told it would be. Best I've pulled is 14.5. I have one injector thats missing on me inconsistantly. I'm running 5 psi on the highway at 60mph, and it peaks at 11psi when i beat the hell out of it. I've still not installed the overdrive unit. I've just been busy as hell with ebay.
#136 |
What?? That's stupid. Sacramento sure is weird sometimes. Well I'll have to stop by sometime and check out your burb since school starts back up next week sometime.
My buddy also has a 6.2 in his 71 K10 with just a stock 4 speed and he's getting around 20-22 mpg with that, so you should see a big difference with that O/D.
#137 |
Resident of Here
What size tires do you have? Also, how much did you turn up your IP?
#138 |
Parts Hunter
I'm running 245/75/16 and the IP is ALL the way up. I'm sure its turned up more than it needs to be, but I had a shop do it and they leaned on the side of overfueling versus potential damage from overboosting.
#139 |
Parts Hunter
On the fun side of life, I'm putting rear discs on the dana, since the drums no longer work.............so I hope to have a sweet burnout vid coming.
#140 |
Parts Hunter
Sorry but no burn out vids. The rear discs were a total pain in the ass to install. One side lined up really nice and the other side was a total battle. But they are on the truck and fully functional now. After 12K miles I've got a new laundry list of stuff to do to the truck.
1. rebuild the turbo. I'm going through oil at a horrifying pace. Rebuild kit is on the way. 1.a. Install heater. It has only been media blasted and refinished since January. 2. Install pyrometer and have injection pump properly tuned. 3. New Injectors if needed. Fuel economy sucks. 4. Brand new aluminum radiator, and electric fans in the summer. The stocker is not in as good of condition as I had hoped.
#141 | |
Resident of Here
2. Good idea! 3. Have your current injectors tested by an injection shop. 4. Make sure you get a rad with an oil cooler and trans cooler built in, it's worth it in the long run. Also, go back to the mechanical fan. As Bill Williamson from Ron Davis Radiators said to me "New trucks still have mech fans. There is a reason for it. If your truck isnt staying cool then switch to an aluminum radiator. The stock fan is more than enough."
#142 |
Parts Hunter
I rebuilt a GM8 turbo I had on the shelf. Now I have to make a turbo master for it as the GM3 bracket will not fit the GM8 turbo. I also don't want to shell out another $120 for a new one. So I've found a few links to show how to use the vacuum unit to make a home made turbo master. Other reason I want to ditch the mechanical fan is I have no shroud for it, and honestly I have no desire to make one. The fan is 21" so a stocker is out of the question.
#143 |
Parts Hunter
Well I blew the motor up today. I'm drowning my sorrows at the bar now. Going back east for vaca and gonna ponder my options. Thinking of **** canning the gmc for a new truck right now.
#144 |
i say put a nice 327 in it or parting it out it does have nice parts and if you do i would like to have first dibs on the passenger side fender and the port windows and some of the dash knobs not to be like a vulture
#145 |
I had a V-8
Sorry to hear of your loss. Keep an eye on craigslist or on other boards classifieds as 6.2L and 6.5L motors come up typically for $500 or less. Just some food for thought.
1972 K20 Suburban, 5.9L Cummins, Banks Power Pack, NV4500HD, NP205, H.A.D., D60/14FF ARB Link To Build: HERE. |
#146 |
PM me how much you would want for the whole thing. My buddy might be interested in it as is.
#147 |
Parts Hunter
Going to buy an 85 2500 with a 6.2 and 700 to get me by for now. Its from a good friend of mine who will stand behind it.
#148 |
Parts Hunter
Drove the 84 GMC 6.2 and 700r4 home today. Runs and drives great. Gonna reg. it tomorrow and put it to work. I'll be pulling the wheels, and receiver hitch off the gmc but I'm thinking that I'm going to part it out. This truck has been that girlfriend that keeps cheating on your and you still go back to her. I think its now time to part ways. To everyone who has been watching the thread have a good holiday and new year and I'll see you next year. If I determine that parting it is best for me the truck will run through ebay in pieces.
#149 | |
#150 |
Hey sorry to hear about your motor. I'm working on swapping a 6.2 into my '68. Trying to get the motor mounts figured out. Did you use the SBC stands and mounts? or did you have to get BBC stands?
'68 C10 LWB 6.2NA/NP833 3.73's |
| Bookmarks |
