Old 12-21-2010, 10:08 AM   #26
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: Sheared seat belt bolts, need advice
if th is thread does not change in attitude quickly it will be locked .
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 12-21-2010, 10:56 AM   #27
motornut
78K & 79C Jimmys
motornut's Avatar
Yikes not the best way to ask/get help
the "weld a bolt after it shears off" is the best fix i know of
(worked on manifold studs,lost locking wheel nuts,done this lots of other places)
i tried sand blasting of the bolt clean at the bottom didn't help
Snapped all my torx
It was suggested in another thread to grind the head square to fit a socket...
to bad your past that point
If your choice is to drill it out you can use large size proper grade bolts and large washers to repair this problem
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 12-21-2010, 09:24 PM   #28
dswancutt
Really the only other option you have is to lower the gas tank and grind off the welded nut, then replace with a bolt of the proper hardness. I had to do this on one of my trucks, but luckily it was the side without the gas tank.
dswancutt is offline   Reply With Quote
Old 12-22-2010, 04:17 AM   #29
rayfinseats
Drill them dead center. Start small like 1/8 and work your way up to about a 5/16 bit. The threads will practically fall out. I do it all the time. Drill a little smaller than the bolt size.
rayfinseats is offline   Reply With Quote
