hey all,,, i am new here so i am not to sure how to gather info yet so i will go ahead and ask some??? i am trying to get my turn signals and running lights sworking on the old truck. i need a wireing diagram i guess. so far the lefrt blinker works but that is it. the right blinker doesnt even make the flasher click. any advise. i am what alot of people consider very mechanical but to be honest lights throw me for a loop. i do body work, rebuild motors, rebuild trannys and diffs, you name it i have done it but ask me to wire up some trailer lights and i will be pulling my hair out in no time.
Active Member
![]() Join Date: Jul 2007
Re: 67 light wireing
Go to "Forums" above then scroll down to "Electrical" and then then scroll down to diagrams.
Is the wiring intact in your truck? If it's all messed up, you may want to buy a wiring kit to make life easier. Also, make sure all your ground straps are new and have good clean connections. I had to add several in my old truck to help the lights work better. Amazing the difference. Here's a site diagram: http://outintheshop.com/faq/wiring/wiring.htm |
thanks thats what i was needing..
ok i posted in electrical forum with no responce//// i need to know if 67 had running lights? when i pull the headlights on they go off. but they work if you pull the light switch out to the first position with the head lights off,
No running lights on 67
Mark 67 c20 custom camper 55 Olds 2dr hardtop 96 mustang 11 dodge nitro |
could be the turn signal swith in the column behind the steering wheel they go out on a lot of these old trucks and cause all kinds of lighting and turn signal problems.
#8 | ||
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
You have tail lights with park lights on and you have tail lights with head lights on. When headlights are on you do not have park lights on.
