Old 12-22-2010, 08:04 PM   #1
allengator
allengator's Avatar
Can anyone tell me what this vacuum switch (?) is ??
This appears to be a vacuum switch with wires on one side an a vacuum port on the other... Mounted on the firewall btween the brake booster and the power junction block.
anyone know what it does??
Allengator
Outta the Blue
(my band - available for hire in the DFW area!)
1980 Chevy SWB Pickup (build thread)
1951 Chevy Sedan Delivery
2004 Chevy Tahoe Z71
2011 Harley Davidson Street Glide
2018 Silverado Z71 Crew Cab
allengator is offline   Reply With Quote
Old 12-22-2010, 08:45 PM   #2
benoit454
Chris
benoit454's Avatar
Re: Can anyone tell me what this vacuum switch (?) is ??
I think that's the tip in switch for the lock up trans convertor be it a 700r4 or a th350c.
The 84 dad has had that one and one on the PS firewall forget what the other was for but one for sure was the tip in switch.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 12-22-2010, 09:04 PM   #3
big_b
yes, it is the lock up torque converter switch for a 700r4,th350c, etc.
if you are running either of those transmissions you should hook it back up to prolong the life of your trans.
big_b is offline   Reply With Quote
Old 12-22-2010, 09:14 PM   #4
dwragon
If the truck was or is a diesel, I think it is a special "LOW Vaccum" switch special to the diesel, to possibly the tranny or something else.
dwragon is offline   Reply With Quote
Old 12-23-2010, 09:48 AM   #5
allengator
allengator's Avatar
TH-350C...!!!!!
I didnt know there was such a beast!!!
After you guys suggested it, I did a little research, and you are right...!
It didnt dawn on me when I saw the electrical connection on the side of it.
I normally play with much older cars!!
Thanks guys!
Allengator
Outta the Blue
Old 12-23-2010, 10:38 AM   #6
Mattman2010
Mattman2010's Avatar
Yes it is the lockup for the TH350C. You do not have to hook it up, if you hook it up it will allow you to run 300 - 500 RPM less when you are running highway speeds. It will not hurt the transmission if you do not run it, it will just act as a normal TH350.
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 12-23-2010, 12:00 PM   #7
allengator
allengator's Avatar
Might as well use it...! Save a little on gas....
Allengator
Outta the Blue
Old 12-23-2010, 01:02 PM   #8
big_b
not having it hooked up does let it function like a regular th350 but it creates more heat in the transmission. heat and auto trannys dont work well together. it is worth it to hook it back up for gas mileage and the life of your trans. it is just a vacuum line from the switch to the manifold vacuum supply.
Old 12-23-2010, 01:29 PM   #9
nbpro
i have the TH350C gas mileage is better with it hooked up
nbpro is offline   Reply With Quote
Old 12-23-2010, 04:53 PM   #10
Jonboy
Slots go on anything!
Since you already have that there, it would work to control the TCC in a 700R4 also. A 700 would also give you a lower first and 2nd gear, as well as overdrive. I mention this since you are on the fence for a trans.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
