Old 12-15-2010, 01:17 AM   #1
del
53 cab on 73-87 stepside 4x4
I have a 1953 pickup and wanted to make it a 4x4. I was thinking of just putting the cab on a 1973-87 4x4 stepside frame and leave the bed. It seems like the 73-87 stepside bed is similar except the fenders. Anyone know about that? This way all I need to do is figure out mounting the cab on the newer frame.
Any input will be appreciated.
I know there have been others who used the blazer frame, but I want to keep the length of the bed. Gonna be my work truck. Thanks
del is offline   Reply With Quote
Old 12-15-2010, 04:01 AM   #2
76whitelightnin'
Re: 53 cab on 73-87 stepside 4x4
I am in the process of doing the same. i have a 76 that i just stripped down to the frame, hopefully mocking up the 58 cab soon. I'll keep you posted on how everything works out. it'd be appreciated if you did the same, this is my first time doin somethin like this as well.
1976 K10 Step-Side.
6/4 lift on 37" open countrys.
jsimotorsports.com
76whitelightnin' is offline   Reply With Quote
Old 12-15-2010, 12:04 PM   #3
355bullet
355bullet's Avatar
i think for the 53 pick up people use the blazer 4x4 frame because of the shorter wheel base..
355bullet is offline   Reply With Quote
Old 12-18-2010, 10:49 AM   #4
Gene Sharp
I have one on the 1980 Blazer frame
it makes a perfectly proportioned pickup
mine has a ZZ- 4
700R4 with a non lockup[ converter near stock stall
and 10' wheels
Gene Sharp
Gene Sharp is offline   Reply With Quote
Old 12-18-2010, 11:34 AM   #5
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Sweet truck Gene!
Ryan
1969 Chevy milk truck
Old 12-18-2010, 11:38 AM   #6
fosheec
fosheec's Avatar
Gene Sharp:
I assume you had to move the axles a bit and extend the chassis - the places I've looked show the Blazer wheelbase as a bit shorter that the AD...
Caleb
fosheec is offline   Reply With Quote
Old 12-18-2010, 02:20 PM   #7
Gene Sharp
No
the axels are in stock location
the fenders require a slight amount of trimming
and the front of the bed is shortened quite a lot
but looks even better
gives it a short powerful look
you can e4ven order bed sides what ever length you need from Markay
Gene Sharp
Old 12-18-2010, 08:52 PM   #8
del
Do you have any more pictures of the truck. Looks great. I was considering a shortbed pickup so I can utilize the full length of the bed and it would be less work.
Old 12-23-2010, 08:30 PM   #9
Gene Sharp
soon as the holidays are over will post pix
am slso doing 56 on 80 4x4 frame that is similar
to some degree
Gene Sharp
Old 12-23-2010, 08:38 PM   #10
Gene Sharp
[QUOTE=Gene Sharp;4366964]soon as the holidays are over will post pix
am also doing 56 on 80 4x4 frame that is similar
to some degree
this is the 80 frame it is about an inch longer that ehe 56 frame
we welded in pieces to fill in the dip where the 80 cab set
with the blazer frame you will end up witha shorter bed
Gene Sharp
