Old 12-24-2010, 10:43 AM   #1
71sierragrande
Petroleum User
71sierragrande's Avatar
Re: Towing and rear suspension opinions needed
Just an opinion, but I would never tow a trailer that weighed twice as much as the truck, regardless of spring or hitch setup.
71sierragrande is offline   Reply With Quote
Old 12-24-2010, 11:54 AM   #2
67chevemall
67chevemall's Avatar
X2 unless you are going around the corner or under 50.
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 12-24-2010, 12:18 PM   #3
BOZO
Old School
BOZO's Avatar
I agree thats a lot of trailer for a short wheel base truck. If it was a long wheel base and had real truck tires on it, maybe. But coil spring overloads can be a helpful thing. I seen in a previous post a picture of some CS overloads that rested above the axle and wondered if these were stock or aftermarket. In the picture below are a set that came stock off a 68 C20. They rest against a plate which sandwiches between the trailing arm and axle. Missing right now is the rubber snubbers that set on the plate. This set bolted right up to the 69 swb C10. I intend to pull a trailer, but only a 14 footer that weighs much less than 9000 pounds.
#1 Project...69 Chevy swb Fleetside (Dad's truck)
#2...1983 El Camino SS (Choo Choo Custom)
#3...1974 Datsun truck (4.3L V6/4L60E)
#4...1951 Cadillac Limo (1975 Caddy running gear)
#5...1938 Dodge M38 3/4 ton Military truck
#6...1968 Sportster XLCH trail bike
5 GMC & Chevy parts trucks 68 to 72
Last but not least;
My 1978 Harley Davidson Electraglide
(trusted & reliable companion for the last 30 years)
BOZO is offline   Reply With Quote
