I have these covers in the pic. I really like then, but they really piss oil.
its all about the +6 inches
Do you get the jegs catalog? I think they have some baffles that you can bold (???) in there.
CCRider
What do you mean by "piss" oil? Do they leak? The biggest problem I have had with valve covers with no baffle is the PVC valve...it will drink a ton of oil if used without a baffle. The way I have aways solved the problem is to use a "mopar" styled push in breather and put the PVC valve inline with the hose fitting that comes off the side. It worked for me.
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
What I mean by piss oil, is that after awhile the tops of the covers are soaked in oil.
Use the factory covers with new gaskets and a pinch of blue sauce and your done!
In most cases the oem parts are always better!! Cheers ![]() |
OEM valve covers are normally better than the chrome ones, but no way are they better than alluminum. The bottom rail...the mounting surface on an aluminum one will never get bent or twisted. True, if you are carefull the stock ones won't get damaged either, but the reality is plenty of them are already there, and many of us have done it ourselves.
Spank 'em if you got 'em!
I'm about to pull my stock covers off and glue the heck out them! I think they may be a little...off. I think "somebody" over tightenend them last time.
Long Knight '71 C-20, 350ci, TH350, Edl. 1406 Carb w/elec.choke, Ignitor ignition, Viper Tires, Orange Dipstick |
mine too. <insert smiley looking in the air and whistling an innocent tune>
Keep On Truckin'
Valve covers
If you want to get rid of them, let me know, I may be interested.
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... |
Score!!! I found the orginal valve covers from my old 72 burb!!!
huh?
![]() Join Date: May 2000
Sweet, then you can put the ones off the 69 on my truck
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
#12 | |
