Old 12-25-2010, 01:07 PM   #1
Ms Bright
HELP!!! See pic; How do I remove this bolt?
I'm installing a KP Components Watts Link and I have a bolt on the upper passenger side on the rear end (see pic) that I need to remove due to interference. I think it might be called the panhard bar bolt(?) possible. Is it threaded thru or does it need beat out? I don't want to screw up threads so hopefully someone out there can let me know. (The pic shown is not my truck; I used a pic off 67 cheby's build cause this is basically what my truck is in the rear before today is over!!!
Ms Bright is offline   Reply With Quote
Old 12-25-2010, 01:16 PM   #2
mikeoj
Re: HELP!!! See pic; How do I remove this bolt?
Take off the nut and give it a wack!!It is a tapered fit stud(not threaded).Should pop right out!
69 Lwb C-10 402/700R4
70 Lwb C-10 250/3pd
Wisc.
mikeoj is offline   Reply With Quote
Old 12-25-2010, 01:16 PM   #3
dfwright
dfwright's Avatar
That bolt is friction fit (pressed in) to the hole. I put a couple nuts on the end and "gently" tapped mine out with a big hammer.
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 12-25-2010, 01:19 PM   #4
Ms Bright
Thanks alot for the quick response. I'll have pics when my install is complete!
Old 12-25-2010, 03:06 PM   #5
cdowns
cdowns's Avatar
if not going to b used then why not just cut and grind the mount and clean smoothe with a cutoff wheel
Old 12-25-2010, 03:45 PM   #6
Ms Bright
it pounded right out. Thanks guys
