Old 12-26-2010, 03:31 PM   #1
jakeblues652
jakeblues652's Avatar
brake issues.
so today i hopped in the truck and let her warm up, because i needed to move her for the snowstorm thats headed our way. reguardless, i was backing it to the spot i wanted it, and hit the brakes, and the front right tire skidded. at that point, i wasnt where i wanted to be, so i pulled forward, backed up, and it did it again. it happened over 10 times, and i need to know whats wrong with them, because i really dont want to go the replace every part route. thanks in advance!
1967 K-10 4x4 with a 3" lift and 35" BFG mud terrains
Originally Posted by Dan in Pasadena View Post
Did you figure out how to fix it?...I mean with other than a BFH?!
want to see some slow progress on my truck? http://67-72chevytrucks.com/vboard/s...d.php?t=436560 <-click there
jakeblues652 is offline   Reply With Quote
Old 12-26-2010, 03:34 PM   #2
cdowns
cdowns's Avatar
Re: brake issues.
best way is to take tires off and get inside the brake drums and inspect your brakes
Old 12-26-2010, 04:07 PM   #3
jakeblues652
Re: brake issues.
i did that last week. the drums were replaced less than a year ago, and the pads are almost new too.
Old 12-26-2010, 04:21 PM   #4
cdowns
cdowns's Avatar
Re: brake issues.
they must b fine then nothing wrong with them
Old 12-26-2010, 04:24 PM   #5
jakeblues652
Re: brake issues.
im not an expert at brakes, but they are definatly NOT fine. when i say the tire skids, like it throws the whole truck around. and only that tire locks up. and if it matters, they are manual brakes, 4 wheel drum
Old 12-26-2010, 04:50 PM   #6
geezer#99
geezer#99's Avatar
Re: brake issues.
Sounds like a leaky wheel cylinder even though you have new shoes and drums. Look for any evidence of brake fluid on your rim or tire. You might need to pull the drum off. If you find brake fluid you'll need to replace the cylinder and the shoes on that side.
geezer#99 is online now   Reply With Quote
Old 12-26-2010, 05:49 PM   #7
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: brake issues.
Re-bleed the system and re-adjust the drag or clearance of the shoes and take her for a spin with several stops, then re-adjust the drag/clearance.
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 12-26-2010, 06:10 PM   #8
jakeblues652
Re: brake issues.
can you give me a step by step? i just dont want to mess anything up.
Old 12-26-2010, 07:45 PM   #9
Pont406
Re: brake issues.
Almost sounds like a primary shoes installed on one side.
Pont406 is offline   Reply With Quote
Old 12-26-2010, 08:09 PM   #10
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: brake issues.
leaky wheel cylinder gets my vote.
Keith
Convert to disc brakes.
Old 12-26-2010, 08:35 PM   #11
rsavage
rsavage's Avatar
Re: brake issues.
+3 on leaking wheel cylinder as a likely culprit.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 12-26-2010, 10:03 PM   #12
skillet
skillet's Avatar
Re: brake issues.
I vote on the wheel cylinder also. My truck did that skid thing a few weeks ago and when I checked one of the front wheel cylinders, a little bit of brake fluid spilled out when I peeled back one of the outside pieces of rubber. When I took the wheel cylinder apart there was surface rust on the inside bore and cup, in addition to the small leak-by. I went ahead and replaced both front cylinders and the truck is braking good.
69 SB GMC LWB Fleetside 350, 09 Pontiac Vibe 2.4 liter
skillet is offline   Reply With Quote
Old 12-26-2010, 11:48 PM   #13
jakeblues652
Re: brake issues.
do i in fact need to replace the shoes on that side? like i said they're almost new.
Old 12-27-2010, 12:02 AM   #14
Boog
laying low
Boog's Avatar
Re: brake issues.
There is no way of completely removing brake fluid soaked into the shoes if that is the case. And no more than a set of shoes cost why would you take the chance?
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 12-29-2010, 05:01 PM   #15
skillet
skillet's Avatar
Re: brake issues.
I would also add that it could be something other than the wheel cylinders. As I previously said, I had replaced the front wheel cylinders and it was braking good. But then, today it skidded again. I decided to check the back cylinders and one side looked okay. But the other side there was oil all over the place, not yet enough to leak out of the brake drum, but enough to coat everything. The axle seal is leaking and I think this is the real cause of the occasional skid, at least in my case. Good luck.
Old 12-29-2010, 05:16 PM   #16
jakeblues652
Re: brake issues.
its not an occasional skid. its every time you stop unless you go REALLY light on the brakes. and when i mean really light, like on a flat area taking 60 feet to stop and it wont do it. i plan on tearing it back apart tomorrow to see if that is that is whats wrong.
Old 12-29-2010, 07:07 PM   #17
1970 Bowtie
It's all in the timing
1970 Bowtie's Avatar
Re: brake issues.
I never take shortcuts when it comes to brakes,I would tear both sides down.Replace the wheel cyl. and hoses and inspect to see what else needed to be repaced.My truck would pull to the right real bad everytime I even touched the brakes.I rebuilt both sides and now I can slam the brakes and let go of the wheel and it will stop strait asd an arrow.
1970 Bowtie is offline   Reply With Quote
Old 01-06-2011, 11:13 PM   #18
jakeblues652
Re: brake issues.
wheel cylinder=replaced and bled, and still same results. have the DR side WC too, gonna replace that tomorrow, if we arent rolling in the snow all day. any other suggestions?
Old 01-06-2011, 11:50 PM   #19
cstm68
cstm68's Avatar
Re: brake issues.
replace bolth front hoses
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308
2014 Chevy 2500hd duramax CCLB
cstm68 is offline   Reply With Quote
Old 01-07-2011, 12:21 AM   #20
jakeblues652
Re: brake issues.
the flex lines were recently replaced with metal braided line. and the front lines from the proportioning valve also look newer.
Old 01-07-2011, 04:37 PM   #21
jakeblues652
Re: brake issues.
okay, so both WC's = replaced. still same problem. bled the brakes and all that jazz too. some pedals, ill have full pedals, and other pedals i need to pump it before theres any pressure. it was the same before, and i could have sworn that this would fix it. whats next, proportioning valve?
Old 01-07-2011, 04:55 PM   #22
coloradosean2009
coloradosean2009's Avatar
Re: brake issues.
Sounds like the MC to me.
__________________________________________
Sean
1972 C20
2005 4Runner
coloradosean2009 is offline   Reply With Quote
Old 01-07-2011, 05:12 PM   #23
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: brake issues.
the master wont make one side lock and not the other.
adjust the shoes to where they are dragging ever so slightly and test drive.
Old 01-07-2011, 05:26 PM   #24
Murphy IRE
Re: brake issues.
Double check your wc, if you put in a rebuilt part doesn't mean it's good. I've had one caliper last a year and then 4 more until I got one that was good. If they are good, it sounds like the MC.
Murphy IRE is offline   Reply With Quote
Old 01-07-2011, 06:34 PM   #25
lolife99
lolife99's Avatar
Re: brake issues.
If the brake shoes were saturated with brake fluid,... they will still grab.
Change the brake shoes, and clean the drum prior to reassembly..
Keith
