67 68 e brake cables questions????
is a 67 68 ebrake cables from the cab to trailing arms are they the same as 69 72 . another question can i get those cables from a different 67 i found one with leaf springs instead of coils
Grandpa in the rustmobile...
Re: 67 68 e brake cables questions????
Id say the cables are the same in the middle as far as leaf coil (67-68) the one closest to the drum would be diff. if I had to guess...ya dont have an extra LR cable for coils ya wanna sell do ya (mine snapped when I got t boned months ago, and cant find a replacemtn that fits worth a darn)
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#3 | |
Might be able to help you out. Spike ![]()
68 stepside http://67-72chevytrucks.com/vboard/s...0&goto=newpost |
well the one that goes from the handle to the trailing arms
What?
Far as I know, the 67-68 E Brake cable from cab to frame is not reproduced and it is different from all the other years.
Unfortunately you may be relegated to using salvaged parts. OR... This hurts me to even bring it up, but "in-line tube" may be able to help you out. They built my cables from drum to frame, since they are not reproduced. I just sent them my originals and they built new ones using my old ones as a pattern. They came out perfect, just the whole transaction process is expensive and frustrating.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
Who's got steelies?
![]() Join Date: Feb 2006
On the 1/2 tons, the brake cables 67-72 are all the same except the front cable that goes from the adjuster to the handle is different 67-68 and 69-72. They are still made, I got mine from LMC years ago and it has worked great. Other vendors may have it too.
![]() ![]() ![]() ![]() ![]() ![]() How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
thanks oldgold70c10 and thanks to every one for the help
