Resident of Here
Bump in the front end? Pushing it?
Well, we got 5-8" of snow here last night and today. First time I've had to put the burb into 4wd. I swapped in a 40K mile rebuilt 10 bolt back in February; according the the dealer that did it, it's a 3:73. The SPID on the burb says it came with a 3:73. The NP208 was resealed 2 years ago.
Well, dad locked the hubs and put it in neutral, then I locked it into 4HI. The county doesn't like to plow, so the roads had tire track rows from where multiple car had driven. The whole time dad was driving the truck was lunging left and right. Mind you we don't drive in the tracks, we drive in the bulk of the muck, as to help clear the road. After going about 5 miles under 30mph in slush, snow, ice, and asphalt it started to do some really weird things. It got down to the point it seemed like the truck was pushing the front end to make it turn. I told dad to drive to some asphalt and idle forward, he did and the truck stopped itself, if the hit the gas it would then feel like we went over a lump in the diff or something. I hopped out and looked at the pinion yoke as he pulled forward and back a few times, just a little bit of play in it, nothing big or obvious. So what do you guys think it could be? Thanks, Bradley
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
Re: Bump in the front end? Pushing it?
First thing i'd do is verify the front and rear gearing, start with ether end and jack one of wheels of the truck up and spin the tire with the truck in nuteral and count the number of times the driveshaft turns to the tire turning 1 revolution. if the drive shafts turn 3 3/4 turns to one of the tire its a 3:73 to 1.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
White 82
I agree u better check the gears to make postive shure there the same... Pull covers and count teeth
1966 GTO 455 e-heads, 1982 Chevy k10 4'' lift 33’' tires, 2008 Pontiac g6 v6 |
Yea sounds like different ratios. You have a rear posi? Is the front open?
Gears X4.
-Marcus 1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's 1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow 2022 Silverado 3500 L8T Project Daily Driver Project Heavy Hauler Project Plow Truck Last edited by MTCK; 12-27-2010 at 08:55 PM. |
Resident of Here
Thanks guys, I'll have to check it. That's what I thought, but dad didn't agree. The rear is posi(sometimes). I think the front is open, but we dont know yet.
If the rear is a posi then when you jack up 1 wheel, put it in nuteral and spin it to could revolutions it won't spin, you'll have to jack up both wheels and spin them both at the same time.
