12-13-2010, 01:07 AM | #1 |
Lowering Questions
I am going to be lowering my 69 C20 in the next couple of weeks. I have sourced a pair of Jeep rear coils and was researching my best options for the front. What do people recommend for the best ride in the front. Cut stock springs, Accord V6 springs, etc? Also, I have never cut my own coils before. Could someone post a pic of a marked coil so I can see right where to cut them?
12-14-2010, 11:54 AM | #2 | |
67-72 parts collector,…
Re: Lowering Questions
True, they will lower the truck,... but I think your load capacity of the truck will suffer. I like purchasing drop springs designed for these trucks. They come in all sizes up to a 6" drop. Depending on how much the Jeep springs lower your truck, will effect the need for rear drop shocks. I also like using drop springs up front,... but cutting the stock springs is fine if you don't cut too much. I use this formula: 1/2 coil cut = 1" of drop. This is an approximate. I don't recommend cutting over 1-1/2 coils, because this will give you an approx. 3" drop. Also 3" drop springs is the max you can do up front and still be able to re-align the front suspension. Front drop shocks need to be considered also.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 12-14-2010 at 11:57 AM. |
12-14-2010, 12:08 PM | #3 |
Alway cut the bottom of the front springs.
I use a cut-off wheel in a air or electric grinder. The red line drawn on the left spring illustrates where to cut "1 full coil". The hardest part of cutting coils is safely removing and reinstalling them. Another important issue is aligning the upper spring "pigtail" in the pocket in the frame. They are real easy to get out of position, which can result in an unlevel ride height.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 12-14-2010 at 12:09 PM. |
12-26-2010, 05:23 PM | #4 |
Thanks mate. Actually having the image when i go to do it will help me out a lot.
Posted via Mobile Device |
12-27-2010, 12:00 AM | #5 |
Grandpa in the rustmobile...
Im running jeep springs/1 coil cut from front springs, doesnt ride bad like alot of folks say..
But the jeep springs wont let you haul much of anything heavy (over100lbs or so) I *may* cut another 1/2 round of the coil off but im worried that if I do that they wont be able to align it...
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
