Old 06-25-2003, 12:01 AM   #1
1971 Cheyenne
1971 Cheyenne's Avatar
Intake Manifold
Hey everyone,
I have a Edelbrock Performer intake manifold. It has been used and while it is not corroded or anything, it does have some oil stains and is pretty dirty and so on and so forth.
I love the clean look of brand new intake manifolds and would like to make mine look like that once again. How would you all clean this so it looks like new? Beadblast? and what would everyone coat it in to protect it from getting stained and messy again?
thanks!
'71
Brian Pal
1971 Cheyenne 10 454/th400-Undergoing a full frame off resto.
1972 Chevy short/step 2wd, 350/th350
1983 M1009 CUCV Military K5 Blazer
1981 Dodge 1 ton 4x4 dually flatbed
1971 Cheyenne is offline   Reply With Quote
Old 06-25-2003, 12:10 AM   #2
Piston
Piston's Avatar
Have it bead blasted (cost about 20.00) then have it clear coated. It will look BRAND NEW.
Piston is offline   Reply With Quote
Old 06-25-2003, 12:22 AM   #3
pissonNOS
senior member
pissonNOS's Avatar
i went to the auto store and got some aircraft enamel remover its completely safe for aluminum and cost 5 dollars a can spray it on and rinse it off. the guy i bought my intake from sprayed the whole thing blue so im sure your oil stains will be no problem for it
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 06-25-2003, 08:14 AM   #4
hanssolo
hanssolo's Avatar
I agree with Piston. Clearcoat after cleaning and painting. Cast alum. is very porous and holds grime easily. Clear coat makes it slick and easy to wash off. I also used it on my alum. wheels.
69 C10 longbed: 357c.i. /TH400/3.73s/AC/ beige primer/saving $ for paint
______________________________
hanssolo is offline   Reply With Quote
Old 06-25-2003, 08:50 AM   #5
VTKidder
I have the same intake, and had the same problem. I beadblasted it, the used off the shelf clear coat spray paint, and really hit it hard after a solid cleaning. I put on 5 or 6 coats, masking off the top deck and where the bolts would go into the heads to ensure the correct torque on the bolts. I haven't cleaned it in a long time, but with some 409 on a shop rag, grime comes off, and it's a pretty smooth finish.
VTKidder is offline   Reply With Quote
