Re: 58 apache 31 stepside noob project help!
What are my options engine wise to replace my 235? I am looking for direct bolt on, no welding. Is it worth spend more to rebuild and keep the original 235?
These trucks came with 283's so any sbc including the first generation or 350's will bolt in. You can use the stock front mounts (see my thread) or buy a bolt on saddle connector that goes frame to frame. You can find an original v8 bellhousing that uses the same mount as the 235 or get an aftermarket bolt on crossmember that supports the transmission. You will spend more to rebuild the 235 than on a good used sbc and 350/400 transmission. And you will have something you can drive over 55 without it sounding like it is going to explode. 235 was (is) a good engine for what it was intended for, 1958 utility truck before freeways when 2 lane road speeds were 45 mph. Put it in granny gear and a 4.10 rearend and it will climb a tree, I hauled a loaded 700# camper and family of 4 all over Idaho for 10 years with a 235, 4 speed, 4.10 rearend setup. In 85 I dropped in a 283, th350 and 3.73 rear end and actually got to spend more time camping than getting there.
