Old 12-27-2010, 07:55 PM   #376
Tri5Nerd
Tripple Five Fanatic
Tri5Nerd's Avatar
Re: Lurker OrrieG Progress Pics
I'm going to go with a 10" sub to reduce the space needed. Or they now have subs that don't require that much space, I forget what they call them. Doh! I just looked them up, they're called shallow sealed subs.
Where you going to put your amps?
Tri5
Originally Posted by OrrieG View Post
Tri5 that is a good idea, would keep them from getting beat up by stuff down low on the floor and keep the storables more out of sight. Sub may or may not stay. I can always add it later. Thats the feedback I am hoping for by posting it.
1955 Chevy Stepside/LS1 drive train
http://67-72chevytrucks.com/vboard/s...d.php?t=371513
Tri5Nerd is offline   Reply With Quote
Old 12-27-2010, 09:07 PM   #377
OrrieG
OrrieG's Avatar
Originally Posted by candyx View Post
Nice sketch but forget the rod holders and make it for a rifle and shotgun, seeing how our world is so messed up!!!!!!!
I was trying to be PC and not perpetuate the Redneck Idaho image! There will be room for the 12 ga, 3.06 and Glock backup.
Old 12-27-2010, 09:11 PM   #378
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Very nice!
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 12-27-2010, 09:13 PM   #379
OrrieG
OrrieG's Avatar
Tri5
I have room under the seat the bottom of the metal frame is about 4" above the floor. I am going to mount the amp in the middle with slid out storage drawers on each side. The way I set up the seat they can tilt forward or be removed just like they were in the Yukon third row. The seats sit flush with the floor in the Yukon so nothing will hang below my frame. Here is the idea:
Old 12-27-2010, 10:40 PM   #380
candyx
candyx's Avatar
Thats good, just wanted to know if i was in the right forum.They used to make jokes about Rednecks but i think they will be the only group left to save the county.......
candyx is offline   Reply With Quote
Old 12-28-2010, 08:16 AM   #381
bensimmons_05
bensimmons_05's Avatar
Is there anything on your seat rail to prevent the seats from sliding sideways on the rail back and forth? I just got to looking at it.
---Ben Jammin's 1955 Chevy/GMC Project ---
---The shop's live video feed--- <<< See what I'm up to!
bensimmons_05 is offline   Reply With Quote
Old 12-28-2010, 01:46 PM   #382
OrrieG
OrrieG's Avatar
When both sit side by side the outside latches have about 1/4" clearance to the main 1x1 frame. After I get them installed and drive it a bit so they settle I will make some shims and bolt them into place. The stock brackets have about 1/2 clearance side to side on the front and more on the back. Here is a setup that used the stock brackets on a stock blazer or suburban floor with recesses added in the floor. You can see even the stock ones have some room to go side to side.
Old 12-28-2010, 02:04 PM   #383
Spackle100
You have a PM sir...
Spackle100 is offline   Reply With Quote
Old 12-28-2010, 07:55 PM   #384
OrrieG
OrrieG's Avatar
replied
Old 12-29-2010, 12:23 AM   #385
bajabob
bajabob's Avatar
Nice work Orrie.... watching how your sound system goes together... Still have a ton of work to do before I get there...
bajabob is offline   Reply With Quote
Old 12-29-2010, 01:22 AM   #386
Tri5Nerd
Tri5Nerd's Avatar
The 4" height is enough for the biggest amps out there, you don't mind if I steal your idea for the amp?
Tri5
Old 12-29-2010, 01:31 PM   #387
OrrieG
OrrieG's Avatar
Tri5
Hey, it's not stealing in my mind, just passing on information, that's what this board is all about. It certainly is not a unique idea, I've seen them tucked under the seats in 60's cars too.
Old 12-29-2010, 01:33 PM   #388
OrrieG
OrrieG's Avatar
Spackle wanted a copy of my inside corner cab template so I made up a thread in the main section that covers it with the template, photos and narrative about my thinking. Feel free to use it. Patrick
Old 12-30-2010, 07:36 PM   #389
OrrieG
OrrieG's Avatar
My free Vintage Air AC kit (used partial) just cost me $100 in misc small parts, but I have enough to get the under dash stuff installed, hoses thru the firewall and heater hoses connected to the engine. three big pieces left are the compressor, condenser, and accumulator/dryer stuff. Taking tomorrow off, going to try and sneak out and work on my back cab interior infill. Does anyone have infinity 6x9 speakers installed, I need a size for the rough in hole?
Old 12-31-2010, 01:13 AM   #390
bartsim
Your truck is coming together nicely. A quick question. Did you paint the outside of your cab...or just the inside for now? I am not ready for paint yet... just curious. Nice work, I cant wait for my build to get that far.
bartsim is offline   Reply With Quote
Old 12-31-2010, 02:23 PM   #391
OrrieG
OrrieG's Avatar
Just the inside, that was all I could afford for now. I wanted to get it done because most of the interior assembly work is no or low dollar and can be done over the "cooler" winter. Also just wanted to see how I would do with the new gun and paint system, last time I painted anythin, except for primer, was in 1977 with laquer! I have just about everything I need to put it back together and make it driveable. Not complete or finished just so I can start driving it again.
Old 12-31-2010, 09:13 PM   #392
OrrieG
OrrieG's Avatar
Stove got the shop to decent temp. Spent the morning doing honey-do cabinetry for the wife "since I had the woodworking stuff set up" as she put it. This afternoon did the corner mock ups. Made templates, trimmed, cut the pieces, trimmed, notched, etc. The cab corners are a pretty complicated 1/4 section of a oval shaped cone. Here is where I am. Had Ms. Joan hold up an old 6x9 for reference. Rethinking the size, not much room behind the inside corner. Have been trying to figure out what to use for the curve then it dawned on me I have all this blueprint protective cardstock at work I use for model making. Worked like a champ, nice smooth radius, should take the fiberglass well.
Old 01-01-2011, 02:07 AM   #393
bartsim
It looks like the paint turned out great. I would like to get my cab back on the frame soon. I need the room. It seems like I spend a lot of time moving pieces from place to place...just to make room for the current project at hand.
Old 01-03-2011, 12:20 AM   #394
OrrieG
OrrieG's Avatar
Went to the big box fabric store. Wife had been there twice and the auto stuff they had way too light of grey. I went looking for alternative, while wandering around found a rack of odd end stuff. Found just the grey I needed, it the amount I needed. Expected to pay a lot for it when it was said and done with mill end discount, 50% off and another discount walked out with 48" x 54" for $3.84. Enough to do behind the cab and corners, front kick panels and maybe some for a transfer case shift boot. The "real" stuff to match my seats was $175 for a hide, this is close enough and will be hidden in the shadows so it will do. Got the frame started for the back panel then the band saw blade started jumping off the wheels. Was cold and hungery so called it a day, no pics, will post when the back is ready. Also found out that for some reason 1/4" x 2' x 4' oak panel was less and nicer than the fir plywood. So far I have less than $15 in my back panels.
Old 01-03-2011, 12:33 AM   #395
bajabob
bajabob's Avatar
Orrie
Not sure how you do it up there in the really cold north west.... Raining and chilly here all day... wha wha... Looks like she is coming along nicely... like the color of the paint as well.
Old 01-03-2011, 02:34 PM   #396
OrrieG
OrrieG's Avatar
Wood stove gets the inside temp up to 45-50 which is manageable when it is below 25 outside. Obviously can't do any body work, fiberglas, painting, etc at that temp. I have space in a commercial building that I can use for short term stuff (like applying upholtery fabric) that does not have long term odors. Can't paint there, its an office, but am thinking I might even do some fiberglas work in one of the restrooms with a good fan. Also going to use it to layout and organize the wiring.
Old 01-03-2011, 05:09 PM   #397
1lo67
1lo67's Avatar
Looking good...i think that color goes well with these old trucks.
1lo67 is offline   Reply With Quote
Old 01-03-2011, 05:10 PM   #398
bjcaldwe
bjcaldwe's Avatar
I see some ideas I will have to borrow. Nice work.
My AD Truck Build Thread
52 GMC one day laying on the running boards
2004 Chevy Crewcab. 3/5 and notched
bjcaldwe is offline   Reply With Quote
Old 01-09-2011, 08:11 PM   #399
OrrieG
OrrieG's Avatar
More progress on the interior. The back frame is deceptively simple looking, but took hours to fab. The cab back curves inward and slopes slightly top to bottom. The bottom of the window frame has a slight tilt, it's not parallel with the floor. And there is the cab mount bracing to deal with. Here is photo of the back frame installed and a shot of the back side showing the fine tuning to fit. The blocking is for gun racks or storage bins I'm going to add later. Decided to just keep the back simple instead of trying to fab and fiberglas compartments.
Frame is screwed to floor and upper inside flange with #10 Tek screws. They have a built in drill so you do not have to predrill and try and find your holes. I have used them to hold wood studs to 1/4" steel columns (need a 1/2" drill motor to drive those!) I decided to hold off on finishing the speaker enclosures until I get the ones I want. Found there is too much variance among 6x9's in size and depth.
Also insulated the back of the cab and corners, feels like progress. Used 3M super77 to stick it in place. Insulation is the foil air pocket stuff from big box home store. Should help with sound dampening and keep the cab cooler. Make sure you mask off anything you do not want the adhesive on. I have used it for years at work and found it is next to impossible to get off of anything. Definately do not want to breath it.
Old 01-09-2011, 08:29 PM   #400
JML55
JML55's Avatar
Nice progress, looks good.
JML55 is offline   Reply With Quote
