Old 12-26-2010, 11:01 PM   #1951
daverod
SSN 706
daverod's Avatar
Re: Daverods project 66
I did fill it up with thinner I just never took the tip off and cleaned the needle thing. I think a piece of teflon tape got stuck in there some how. I cleaned them good with some fresh thinner ready for round two. Well, as soon as I go get some more hardner. Sanded down what I did with some 120.
daverod is offline   Reply With Quote
Old 12-26-2010, 11:38 PM   #1952
Strodder
Daring to be Different
Strodder's Avatar
Originally Posted by daverod View Post
Cool thanx. I'm thinking I'll be needing that. Got the slicksand sanded with 100 grit. Ready to spray with some g2 feather fill. I love spraying. How did I ever get along without a air compressor? Changed the oil out yesterday. Need to go to HF and get a air chiesel today. Heating my spray room up as we speak. Wonder if I should get a Imlala dash harness?
Yeah why not. Good idea
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 12-27-2010, 12:22 AM   #1953
AZ66GMC
Desert Dweller
AZ66GMC's Avatar
Looking good
I like the simple notch. I'm thinking about the same for my truck
That dash is way cool too!
Keep up the great work and keep the pics coming
Tony
Tony
66 GMC LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=399283
AZ66GMC is offline   Reply With Quote
Old 12-27-2010, 12:22 AM   #1954
daverod
SSN 706
daverod's Avatar
Just wondering how it would plug into the painless harness? My arms hurt. Drilled like a million holes for my notches. Pan bar really sucked should have just welded it.
Old 12-27-2010, 12:29 AM   #1955
daverod
SSN 706
daverod's Avatar
Originally Posted by AZ66GMC View Post
Looking good
Tony
Take your bed off when you do it. Makes way easier. Got mine off ebay for 90 plus shipping. Plan on doing a lot of drilling. Get some good new bits. Easy to do. Just grunt work. Round the corners of your cuts so the frame won't crack.
Old 12-27-2010, 12:35 AM   #1956
Strodder
Strodder's Avatar
I'm sure you can splice it in.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 12-27-2010, 12:38 AM   #1957
AZ66GMC
Desert Dweller
AZ66GMC's Avatar
Thanks for the tips. Are you welding yours up too? I was going to weld mine and just use a few bolts. Also, my drill doctor is one of my favorite tools. I've got plenty of sharp drill bits
Tony
Tony
66 GMC LWB
Old 12-27-2010, 12:52 AM   #1958
daverod
SSN 706
daverod's Avatar
Ya I'll weld the inside. I'll have to look up the drill doctor. I could have used the doctor today. I did put the floor jack under the drill a couple times really helped.
Old 12-27-2010, 01:25 AM   #1959
AZ66GMC
Desert Dweller
AZ66GMC's Avatar
Huh, floor jack, I never thought of that one
Tony
Tony
66 GMC LWB
Old 12-27-2010, 11:11 AM   #1960
watahyahknow
watahyahknow's Avatar
on the old the vilbis paintguns you could unscrew the air adjustment remove the spring and pull the needle out of the back of the gun to clean it (carefull theres a foamrubber like seal there to keep the paint from spitting out the back ) and they had a nifty tool to unscrew the nozzle itself behind the head , we had small pipebrushes to clean the nozzles if sumtin like that happened the nozzle is a precicion thing you dont stick metal objects like screwdrivers in it or you ruin it and it wil spray and sputter the weirdest patterns
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 12-27-2010, 12:34 PM   #1961
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Not sure how the harness of the impala hooks up. The painless one has spade terminals.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 12-27-2010, 12:46 PM   #1962
daverod
SSN 706
daverod's Avatar
I'm going to get some of those pipe cleaners. I was just letting it set in thinner and running thinner thought it. Works for a few times but after awhile it gets cloged.
Old 12-27-2010, 12:47 PM   #1963
daverod
SSN 706
daverod's Avatar
I knew it! This going to require duct tape is'nt it ?
Old 12-27-2010, 01:38 PM   #1964
ruffrida2005
Duct tape, bailing wire, bondo, gerber and some gum! You'll get it figured out
! I'm about to go mail it off as soon as my wife gets in. I'll let you know the tracking number.
Paul
Old 12-27-2010, 02:38 PM   #1965
daverod
SSN 706
daverod's Avatar
Thanks Paul
Old 12-27-2010, 06:04 PM   #1966
watahyahknow
see if you can get a rebuildkit for the paintgun , ask first if it does but i believe they included the brushes and the multitool along with a new needle nozzle and seal
that way you can soak the one and use the other if it is clogged
Old 12-27-2010, 06:05 PM   #1967
daverod
SSN 706
daverod's Avatar
Just sprayed some Hot Rod Flaz burnt orange worked great.
Old 12-27-2010, 07:51 PM   #1968
ruffrida2005
Man that looks great, Please do me a favor alright. On the tail gate can you put a white bull, and say hook'em.
Paul
Old 12-27-2010, 08:35 PM   #1969
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
You need to quit messing around and get that harness figured out.
At the rate you are going you will be there first.
Alan's Classic is offline   Reply With Quote
Old 12-27-2010, 09:12 PM   #1970
daverod
SSN 706
daverod's Avatar
Started to spray the inside of my cab. Learned the fine line between looking really good and running. Guess I'll have to wait about a week and do alittle sanding.
Old 12-27-2010, 09:13 PM   #1971
daverod
SSN 706
daverod's Avatar
The more I work on painting my truck the more I realize your the master. I like the way you painted your firewall. I was have a hard time spraying in there with the dash in the way.
Old 12-27-2010, 10:36 PM   #1972
tiggamonsta
tiggamonsta's Avatar
You definitely need some horns on that truck.
tiggamonsta is offline   Reply With Quote
Old 12-27-2010, 10:49 PM   #1973
ruffrida2005
Hook'em son.
Paul
Old 12-27-2010, 11:34 PM   #1974
daverod
SSN 706
daverod's Avatar
Getoutahere.
Old 12-28-2010, 12:27 AM   #1975
bubba327
HOW long until spring??
bubba327's Avatar
Hey this is Bronco Nation Can't you guys see that is BSU Bronco Orange...Go Boise State
I struck out on the 292 power steering brackets, I did find one complete set and you are first in line when he makes up his mind if they are for sale Looking good Dave
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline   Reply With Quote
