04-09-2009, 01:44 PM | #1 |
ECE Drop Spindles - what finish are they?
Just ordered a set of the ECE drop spindles and was surprised to hear that they showed up raw (no paint or powdercoat on them).
Thought that they might be painted cast - or even clear coated but they are not... What did you guys do to protect them from rusting? Pix would be great - if you have them. Thanks. |
04-09-2009, 01:47 PM | #2 |
Re: ECE Drop Spindles - what finish are they?
my spindles I cleaned them up and sprayed painted them....
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
04-09-2009, 02:02 PM | #3 |
Never Ending Projects
I think just about all aftermarket spindles are just unfinished cast parts.
I painted my argent silver but haven't installed them yet.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
04-09-2009, 02:22 PM | #4 |
senior member
i used caliper paint on mine and its holding up quite well, i assume the main reason for not paintig these parts is there probly way to many colors people could want
69 GMC bagged |
04-09-2009, 03:28 PM | #5 |
Under Construction
cleaned, taped em up, painted silver, cleared, installed em in my son's truck.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
04-09-2009, 03:30 PM | #6 |
PROJECT 7DEUCE
Unfinished cast...
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
04-09-2009, 05:16 PM | #7 |
These are ECE spindles. Did them in cast blast cast iron gray along with all my steering components. The shocks are what they were when I pulled them out of the box.
When I grow up, I want to be the man my wife married. I used to be schitzophrenic, but we're O.K. now |
12-27-2010, 04:42 PM | #8 |
i want to get mine powder coated before i install them. what areas should be masked off ?
thanks |
12-27-2010, 05:01 PM | #9 |
Some things you just have to paint yourself. Especially mechanical parts that are not usually painted on any vehicle.
12-27-2010, 09:10 PM | #10 |
i left mine raw cast ... same as the GM units that they replaced.
12-27-2010, 09:38 PM | #11 |
Watch out for your cornhole !
When powdercoating, mask the spud, ball joint and tie rod holes and the machined slides where the caliper rides.
12-27-2010, 09:48 PM | #12 |
painted mine with engine enamel silver & clear enamel, rattle can $9.00 done
