Old 12-27-2010, 11:20 PM   #1
67C10BUB
67C10BUB's Avatar
Bad DOD/AFM connector...What to do???
The AFM connector in the pics below is broken and I am wonering what the best course of action is. I am putting the motor in a 1967 C10 pickup and I had the ECM programmed by Speartech. I am getting a P3401, P3425, and P3441, so I am trying to decide if I should just have my ECM reflashed to eliminate the DOD/AFM, or if I should replace this connector and keep the DOD. If I do replace it, what is involved (is this a 2 piece plug that requires the valley cover to be removed)? If I don't keep it, is there any kind of plug to fill the hole in the valley cover? Please someone help. I posted this on LS1 Tech also, but I never get many responses on there.
67 5.3L Build
67C10BUB is offline   Reply With Quote
Old 12-27-2010, 11:26 PM   #2
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: Bad DOD/AFM connector...What to do???
I think you're going to need to post that kind of question at LS1tech.com or performancettrucks.net. I'd get rid of it personally (I did with my motors VVT)...but thats just me. You may be after the extra mpg?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 12-27-2010, 11:37 PM   #3
67C10BUB
67C10BUB's Avatar
I did post it on LS1 Tech, but I have never got a response to anything on that sight. If I do eliminate it, what can I plug that hole in the valley cover with?
67 5.3L Build
Old 12-28-2010, 02:26 AM   #4
tapeworm
fan of "Butters" Stotch
tapeworm's Avatar
I'm sure you could get the connector right from GM, They are not cheap, but could be easier & cheaper than a reflash
64 shortbox fleetside
replacing rusty junk with more junk, and one day to become a real truck again
tapeworm is offline   Reply With Quote
Old 12-28-2010, 01:14 PM   #5
67C10BUB
67C10BUB's Avatar
I was just hoping to not have to take my motor all apart, since I just got it installed. I believe I would have to take off the intake and valley cover to install it.
67 5.3L Build
Old 12-28-2010, 05:51 PM   #6
Clyde65
Clyde65's Avatar
have you spoke to John @ Speartech about the problem, I'll bet he has a fix for you.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 12-28-2010, 07:42 PM   #7
68GMCCustom
if you're going stock or near stock efi....I'll bet you wouldn't want to eliminate it.
Kurt -
Old 12-29-2010, 01:36 AM   #8
67C10BUB
67C10BUB's Avatar
I wouldn't mind eliminating the DOD, but I just wonder if there are parts of that connector left inside the motor, so I think that I may have no choice but to pull the intake and valley cover. BUMMER!!!
67 5.3L Build
Old 12-29-2010, 01:37 AM   #9
67C10BUB
67C10BUB's Avatar
Maybe I'll try tomorrow, but the only options I see are to replace the connector or delete the DOD. Thanks for all of the responses. This is why I love this forum.
67 5.3L Build
