Old 12-15-2010, 08:09 PM   #1
Murphy IRE
installing new shift linkage for 700 R4 and column indicator lense
I have a 71 K20 and a rebuilt 700R4 tranny. It seems the PO never changed the original linkage. I've attached pics of what I have. I can't get the tranny to manually drop into 1st gear. It will only drop as far as 2nd.
My tilt column and linkage are for a 350TH. So I need to pull the old lense (PRND21) and replace with the new (PRND321). I removed the two small screws and the lense doesn't budge! What's the trick?
Also, I ordered a new Lokar linkage kit for a 700R4. In the 1st pic, we did cut some of the column housing away to allow some additional clearance (if needed). Are there any things I need to be aware of or short cuts to help with the install? Thanks in advance!
Pics now attached! Sorry.
Murphy IRE is offline   Reply With Quote
Old 12-15-2010, 08:24 PM   #2
brans72
Re: installing new shift linkage for 700 R4 and column indicator lense
no pics are showing up.
brans72 is offline   Reply With Quote
Old 12-15-2010, 09:12 PM   #3
tonypaul
tonypaul's Avatar
Im kinda in the same situation- I put in a 4l80e with a new chrome tilt column and a Lokar kit. The rod that they sent was to short so I got some allthread from Loews and fabed it up. I have tried adjusting it a couple times now and it doenst seen to go in low gear either. I think I need to shorten the rod some more and adjust the lever up more.
I hope someone will chime in thats been through this...
tonypaul is offline   Reply With Quote
Old 12-15-2010, 11:30 PM   #4
camaney
I think that the shifter prN321 should be ok. The 3 is also overdrive on my 91 pickup
camaney is offline   Reply With Quote
Old 12-27-2010, 11:39 PM   #5
Murphy IRE
My linkage kit was short too. I went with a shop cutting and inserting high grade SS to make up the difference. P, D & 1st line up perfectly. The rest are a little off, but she drops into 1st!!!
The reverse neutral switch needs a little adjustment. The reverse lights only work from drive up and not from Park down. She still won't start in neutral. But I really happy with being able to drop it into 1st
