Old 12-28-2010, 01:36 AM   #1
shortbed70
shortbed70's Avatar
one ton rear?
Any idea what rear end would be in a 86 one ton with a BBC/4 speed? Im debating on swapping rear gears to go down the road alittle better. A gear swap Is cheaper then the transmission option. I was looking at going 5 speed until I priced the nv4500 with pto...OUCH! Here the truck is on the trailer after being stuck 45 miles from home from a stupid $5 switch.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 12-28-2010, 05:58 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: one ton rear?
That truck is a cab and chassis truck. It will have a 14 bolt rearend. Randy's Ring and Pinion carries 3.54 gear sets for them. Also good news is that the 14 bolts are far and away the easiest ones to setup gear sets in.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 12-28-2010, 07:29 AM   #3
b454rat
Re: one ton rear?
They do not make a 3.54 for a 14ff, closest made is 3.42s.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 12-28-2010, 07:49 AM   #4
Tx Firefighter
Re: one ton rear?
He's right. I remembered that wrong. Randy's has a good choice of gearsets though.
Old 12-28-2010, 10:34 AM   #5
87 V20 Scottsdale
87 V20 Scottsdale's Avatar
Re: one ton rear?
Are you going to be working the truck, or mostly just driving it around?
Andrew
1987 V20 Scottsdale 383 TBI, SM465, NP208, 14FF, 4.10
1988 C1500 Scottsdale 305, 700R4, 3.08
1986 K30 Custom Deluxe 6.2, SM465, NP205, 14FF, 4.10
87 V20 Scottsdale is offline   Reply With Quote
Old 12-28-2010, 11:28 AM   #6
shortbed70
shortbed70's Avatar
Re: one ton rear?
It will get used but I don't think it needs that much gear so I can at least drive 65 down the highway without the motor howling at me. I can lug around in 4 gear and cruise 30 mph with no problems. I just want a little more drivability with it. The most it will haul running the highway is my 4k skid steer and maybe 1000 lbs of dirt or rock. Most of the time it will be empty running back and forth from the job.
Troy
Big Red Dog build
Old 12-28-2010, 12:40 PM   #7
bmchevy1979
bmchevy1979's Avatar
Re: one ton rear?
assuming it has 4.10 gears the only choice in between would be 3.73 I believe
<Brandon>
1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works.
1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15
81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in
1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096
1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195
bmchevy1979 is offline   Reply With Quote
Old 12-28-2010, 02:07 PM   #8
shortbed70
shortbed70's Avatar
Re: one ton rear?
Yea they go from 373 to 410. I think the 373 would be fine. I will try to look and see if my rear has a tag or something that says.
Troy
Big Red Dog build
Old 12-28-2010, 06:25 PM   #9
87 V20 Scottsdale
Re: one ton rear?
With 4.10's you'll be turning around 3k RPM at 65. If you were running 55 mph loaded with 4.10's you'd be around 2600 RPM, with 3.73 gears and the same speed would turn about 2400 RPM. If you're going to be working at all with it I wouldn't go any lower than 3.73.
Andrew
Old 12-28-2010, 08:00 PM   #10
Shawn5488
Re: one ton rear?
It will be hard to ever justify the cost of gear swap, I bet you will never come out on top. Having said that my bb\400\3.73 is perfect with stock tire size, will still pull anything yet cruise down the highway.
Why dont you look in the glove box and see what gears you have, you could have 4.88s or something stupid, in that case I would swap them asap!
Shawn5488 is offline   Reply With Quote
Old 12-28-2010, 08:41 PM   #11
b454rat
Re: one ton rear?
If indeed it is a 14ff, you could go low as 3.23s factory. I've never seen them, only one 3.42 in a 2wd.
With a big block, I'd probly go with a 3.73. Still give you some grunt, but still be able to drive and not get passed by gramma....
Old 12-28-2010, 08:45 PM   #12
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Re: one ton rear?
That rear is a dana 60 or 70.
MylilBowTie is offline   Reply With Quote
Old 12-28-2010, 08:52 PM   #13
Tx Firefighter
Re: one ton rear?
No way. Cab and Chassis trucks had 14 bolts. I have two in my driveway now.
Old 12-28-2010, 09:29 PM   #14
sailed2japan
Jonny
sailed2japan's Avatar
Re: one ton rear?
I've heard of (but never seen) Dana 70's get put in some. Never a dana 60, though.
1966 C30, Cummins, stacks, and a flat bed in progress...
"Honor.....simply put,
A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it."
-AEC Hundley USNR
sailed2japan is offline   Reply With Quote
Old 12-28-2010, 09:36 PM   #15
Tx Firefighter
Re: one ton rear?
Dana 70 = Dually
14 bolt = Cab and Chassis
Old 12-28-2010, 11:07 PM   #16
sailed2japan
Jonny
Re: one ton rear?
Did all the duallies come with Dana 70's or just a few?
-AEC Hundley USNR
Old 12-29-2010, 12:36 AM   #17
sierra4x4
sierra4x4's Avatar
Re: one ton rear?
I would go with a 3.21 ratio. I had a 77 3/4 ton Camper Special with a 454/TH400 with 3.21 and it got great mileage (for a 454) and I wound still tow almost anything I could hook up to and if you've got a 4 peed then you will actually be able to use that granny low.
sierra4x4 is offline   Reply With Quote
Old 12-29-2010, 01:02 AM   #18
60-66 Nut
Professional Beer Tester
Re: one ton rear?
Like Tx Firefighter said, cab & chassis one tons had the 14 bolt, duallies had the Dana 70HD until '93 or '94, and after that they had the 14 bolt also. 4.10's were very common in one tons. My '90 R3500 single wheel one ton crew cab has the 3.42's with the 454 & TH400, and it pulls my 5th wheel camper with no problem. I have an '82 dually bed & rear end to make it a dually, but the rear end is the Dana 70HD with 4.10 gears. I really like my 3.42's, so I've been looking around for the later 14 bolt wide axle so I can keep my same gears & limited slip diff. I'll have to move the spring perches and shock brackets because the '93 up frames were wider, but it can be done.
60-66 Nut
60 Ford F100 Custom Cab
61 Apache Short Fleetside
64 C10 Short Stepside
65 C80 409 V8 5spd(X-Firetruck)
83 GMC 350 Olds Diesel
85 GMC Short Bed
86 GMC Short Bed
90 GMC R3500 Crew Cab
92 GMC 1500
60-66 Nut is offline   Reply With Quote
Old 12-29-2010, 01:21 AM   #19
sailed2japan
Jonny
Re: one ton rear?
Wow, learn something new every day.
-AEC Hundley USNR
Old 12-29-2010, 07:06 PM   #20
Shawn5488
Re: one ton rear?
I have seen several cab and chassis trucks with Dana 70's...
Old 12-29-2010, 11:40 PM   #21
shortbed70
shortbed70's Avatar
Re: one ton rear?
Pretty sure its a 14 FF and the tag in the glove box says 4.10. I might just deal with it for a while. I am going to see what the tach says tomarrow when I drive it with the speedo fixed and see what rpm is what speed.
Troy
Big Red Dog build
Old 12-31-2010, 01:08 AM   #22
pilotj
Re: one ton rear?
My truck has the 4.10 14 bolt with a TH400, 265/75R16 tires and it turns 3100-3200 at 65mph. Wish I had left the 3.73's in it. (put the 4.10's in before gas prices jumped a few years back). Still got the other rear...thinking about putting the 3.73's back in
1979 Chevy C20 350/TH400
1974 Chevy C30 350/4speed
pilotj is offline   Reply With Quote
