Old 06-24-2003, 10:53 PM   #1
FILICE72C10
FILICE72C10's Avatar
Drop Sindle installation help......?????
When replacing my front spindles with 2 1/2drop spindles on my 72 C10 SWB, what other preventative maintainance should I do? I already bought the upper and lower ball joints, new shocks, and new rubber bumpers, anything else?
One other question, how hard is it to install the rear shock re-locaters? Do I have to drill out the top mounts and remount the new mounts? Can I do this with the bed on?
Any advice would be great!
thanks!
So you'll know what im working with..... Next weekend it will be 2 1/2 and 4 inches lower!
72 C10 SWB
02 Subaru WRX
95 Nissan 240SX
FILICE72C10 is offline   Reply With Quote
Old 06-25-2003, 07:38 AM   #2
7T1BURB
The original upper shock mounts will have to be removed. I recently did this on our BURB (now with 2.5 dropped spindles in front and 4" dropped rear coils) and cut the rivets of the original rear shock mounts out with a high speed grinder wheel. After removing the rivet heads, I punched out the remaining part of the rivet(s). The ECE shock locators are then bolted to the frame...not a really difficult time and about an hours worth of grinding and cussing.....hope this helps! Good luck on your project.
7T1BURB is offline   Reply With Quote
Old 06-25-2003, 12:24 PM   #3
cdowns
cdowns's Avatar
when i did my spindels i also changed the tierod ends and the swaybar bushings
Old 06-25-2003, 12:53 PM   #4
COBALT
COBALT's Avatar
I used this opportunity to clean up the cross member, and replace my control arm center bars and bushings. Good thing to - there was one that had failed.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 06-25-2003, 07:09 PM   #5
FILICE72C10
Thanks for the advice!
72 C10 SWB
02 Subaru WRX
95 Nissan 240SX
Old 06-25-2003, 10:32 PM   #6
phantom dually
Project92 SWB stepside
phantom dually's Avatar
Put new bearings in and check your brake rotors and pads.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 06-25-2003, 11:23 PM   #7
FILICE72C10
i just did new bearings, new front disks and pads about 6 months ago, so i should be solid, that does make perfect sense it I had not done it already
thanks
72 C10 SWB
02 Subaru WRX
95 Nissan 240SX
Old 07-08-2003, 09:22 PM   #8
Slammed '87
Slammed '87's Avatar
Thumbs up SWEET
Hi, just wanted to say that is a nice ride!, can u post some pic's of it lowered?
Slammed '87 is offline   Reply With Quote
Old 07-08-2003, 10:28 PM   #9
FILICE72C10
here are some pics
http://67-72chevytrucks.com/vboard/s...threadid=58677
72 C10 SWB
02 Subaru WRX
95 Nissan 240SX
